Question d15b swap
Old Jul 4, 2005 | 10:19 PM
b18ef8's Avatar
Default Question d15b swap
OK so im using my stock si harness with a odb0 to obd1 jumper harness and the jumper for the dizzy. My question is what to do with the injectors can I just use my obd 0 ones or do I need to re wire them for obd1? ecu is a p28 or I have a p08
Old Jul 5, 2005 | 08:16 AM
FOMULA91's Avatar
Default Re: Question d15b swap (b18ef8)
You have an Si right? Then you could use your injector. But correct me if I'm wrong because my set up is for OBD0.
Old Jul 5, 2005 | 09:35 AM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ef8 &raquo;</TD></TR><TR><TD CLASS="quote">what to do with the injectors can I just use my obd 0 ones or do I need to re wire them for obd1? ecu is a p28 or I have a p08</TD></TR></TABLE>
You can use the OBD0 injectors, but ya gotta keep the injector resistor box... I would rather use the OBD1 injectors though. Use the p08... its the right ecu for the engine.
Old Jul 5, 2005 | 10:12 PM
b18ef8's Avatar
Default Re: Question d15b swap (Bunger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger &raquo;</TD></TR><TR><TD CLASS="quote">
You can use the OBD0 injectors, but ya gotta keep the injector resistor box... I would rather use the OBD1 injectors though. Use the p08... its the right ecu for the engine.</TD></TR></TABLE> Why would you rather use the obd 1 injectors?I would rather use my obd 0 ones. btw it is a si and the d15 will have the 92-95 greddy turbo kit but no e manage.
Old Jul 6, 2005 | 12:46 AM
Bunger's Avatar
Opening time is a little different for the peak hold and saturation injectors, so match the injectors to the tune. But if you're gunna retune it... guess it doesn't matter
Old Jul 7, 2005 | 12:02 AM
b18ef8's Avatar
How did u wire the obd 1 injectors? I saw something about it on rywire but there info and pics was limited.
Old Jul 9, 2005 | 06:29 PM
b18ef8's Avatar
anybody know how to convert obd 0 - obd 1 injectors?
Old Jul 9, 2005 | 06:52 PM
tcmotorsports's Avatar
To use OBDO injectors on an OBD1 system you "MUST" use a resistor box, due to the fact the OBD2 injector are High inpedence. Using OBDO (saturated) injector with a OBD2 (non-saturated) ECU will cause damege to the ecu.
Old Nov 10, 2005 | 02:19 PM
court's Avatar
25 Year Member
Default how about this question
If I wanted to use obd1 injectors with a non obd ecu, would I not use the amplier box, and run the wires from the injectors directly to the ecu?
obd1 injectors w obd0 ecu
Old Nov 10, 2005 | 11:42 PM
.john.'s Avatar
Default Re: how about this question (court)
all you have to do to change to the obd1 injectors is connect all five wires on the resister box and remove the box. the yellow wire is a 12 volt switched power that can power the new injectors ( four red wires )
oh, cant use 0bd1 injectors on a obd0 ecu. im pretty sure it will damage the injector drivers
Old Nov 10, 2005 | 11:52 PM
NikoZai's Avatar
Default Re: Question d15b swap (tcmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">To use OBDO injectors on an OBD1 system you "MUST" use a resistor box, due to the fact the OBD2 injector are High inpedence. Using OBDO (saturated) injector with a OBD2 (non-saturated) ECU will cause damege to the ecu.</TD></TR></TABLE>
I've been thinking about this too, but i don't see how it would... could you please give me a detailed explination to how switching 5.5v+ instead of 12v+ would damage the ECU?
Note: i'm talkin obd2 ecu running obd0 injectors.
I don't think the amps are that much higher on the 12v+ to cause the paths on the ECU board to heat up on a OBD0 ecu either. I've never known anyone to damage their ECU by running OBD1 injectors on an OBD0 setup.
Modified by NikoZai at 1:04 AM 11/11/2005
92integraVTECgsr
Mar 30, 2010 05:58 AM
a1320addict
Aug 7, 2006 05:03 PM
ALLMOTA92EG
Mar 12, 2005 04:12 PM
dpine
Jul 14, 2004 06:19 PM
cRxAuDio
Jul 21, 2003 01:43 AM
