vtec spool valves
Old Jul 4, 2005 | 06:32 PM
fontaracing's Avatar
Default vtec spool valves
hello everyone,
im looking for a vtec spool valve, solenoid or whatever its called for a 94 civic coupe with D16Z6 engine. Anyone got any links or directions for where to get it?
Is there any way to repair it?
regards
francesco.
Old Jul 4, 2005 | 08:07 PM
Frozen E's Avatar
H-T White Ops
The solenoid is actually bad? Have you tested it with a 12V power supply? If it doesn't open up the windings inside the coil are open and need to be replaced.
I've always had good luck with getting parts from http://www.majestichonda.com
Old Jul 4, 2005 | 08:12 PM
HATCHingMN's Avatar
Default Re: vtec spool valves (fontaracing)
how bad is the solenoid? maybe you can just clean it
Old Jul 4, 2005 | 09:27 PM
Archidictus's Avatar
Unceasing Measure
Default Re: vtec spool valves (HATCHingMN)
Spool valve errors (CELs) usually arise when the screen in the VTEC solenoid has deteriorated to the point of letting **** into the spool valve, thus clogging oil passage into the VTEC sensor.
Clean it out and get a new screen for like $10 at Honda.
Old Jul 5, 2005 | 04:13 AM
i´ve tried cleaning it with carb cleaner. The filter seems fine visually. Going to try 12v directly and see what happends.
regards.
francesco.
Old Jul 5, 2005 | 06:30 AM
chinkest_raver's Avatar
lol its expensive, i have an extra laying around. they will run you for about $200. but pm me if you still need it i can sell you mine for half that price. It;s off a EJ8, but i think it should work for ur Z6 as well...pm me..
Old Jul 5, 2005 | 05:39 PM
Default Re: (*****est_raver)
got the solenoid.
thank you all.
Dontoh
16
Jun 21, 2012 08:21 PM
Flatland2D
Jul 16, 2010 09:14 AM
Midori Green
May 7, 2008 07:10 PM
HU MAN CHU
Jun 29, 2006 09:43 PM
Frosty_spl
Feb 21, 2002 03:19 PM
