should I put a typeR tranny in my GSR
Old Jul 4, 2005 | 04:20 PM
stixGSR's Avatar
Default should I put a typeR tranny in my GSR
I' ve desided to leave my '95 GSR N/A. I was thinking about putting a typeR tranny for the shorter gears and the LSD. What are the pros/cons of this swap?
Old Jul 4, 2005 | 04:37 PM
numbnuts22715's Avatar
the most important ones are
pros
-a little bit faster
-the lsd
cons
-when youre cruising in 5th gear youll have higher rpms, so itll be a little louder if youve got a loud exhaust
Old Jul 4, 2005 | 04:47 PM
TurboGS-R's Avatar
Default Re: (numbnuts22715)
Also for cons is if your tranny is working already, why not just get a much better LSD?
Old Jul 4, 2005 | 05:17 PM
BlueIntegraBoy's Avatar
Default Re: (TurboGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">Also for cons is if your tranny is working already, why not just get a much better LSD?</TD></TR></TABLE>
He wants the shorter gearing
Old Jul 4, 2005 | 07:03 PM
dc2vu's Avatar
might as well get a b16 tranny with a good lsd...probably run u almost the same price..but yes if u stay N/A go with the shorter geared tranny
Old Jul 4, 2005 | 07:19 PM
s2kdre's Avatar
Default Re: (dc2vu)
if u can get one for cheap, i would get it.
Old Jul 4, 2005 | 07:21 PM
dc2legend's Avatar
Default Re: (jdmhonda)
Yes
Old Jul 4, 2005 | 07:22 PM
cleantegra's Avatar
[/QUOTE]the most important ones are
pros
-the lsd
cons
-when youre cruising in 5th gear youll have higher rpms, so itll be a little louder if youve got a loud exhaust[/QUOTE]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">if u can get one for cheap, i would get it.</TD></TR></TABLE>
id say $700 or less, if more than that, go with a quaife about $900, the labor charge is prolly the same for a swap or lsd install
Old Jul 4, 2005 | 09:30 PM
. a d a m's Avatar
Default Re: (dc2vu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2vu &raquo;</TD></TR><TR><TD CLASS="quote">might as well get a b16 tranny with a good lsd...probably run u almost the same price..but yes if u stay N/A go with the shorter geared tranny</TD></TR></TABLE>
Sorry, I'm a B16 hater. Theres nothing wrong with them, but people think B16s are the solution to everything.
Its like some guy could buy a hummer, and you could ask him what hes gonna do with it, and knowing some of you guys, he would say B16 swap with teh awesome B16 tranny wHiCh wE aLl kNoW mAkEs j0o cAr hElLa fAsT y0.
Old Jul 4, 2005 | 09:37 PM
sohcvtec1995's Avatar
Default Re: (Sh!ttyLS)
type r tranny
Old Jul 4, 2005 | 10:20 PM
Bk2fwd's Avatar
You have half a type r tranny right now.
Your solution is to get a 4.7 final drive and a good lsd.
and shazzzam!!!you have a type r tranny
Old Jul 4, 2005 | 10:24 PM
dc2vu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">
all i was sayin is that with the prices of ITR tranny's at the moment ranging from anywhere from 900+ used...you COULD just get a b16 tranny used with a new LSD for about the same price...a shorter geared tranny will make a difference with a N/A motor
Old Jul 4, 2005 | 10:28 PM
NSXtcy21's Avatar
well the b16 tranny with its shorter gearing would make it a great candidate for someone wanting to get up and go fast.. honda lsds can be had from ebay for less than 300 so if you know how to work on trannys then it would be a economically better choice.. but the final drive on a type r tranny is just so perfect.. I'd still go with the R tranny
Old Jul 5, 2005 | 04:21 PM
Bk2fwd's Avatar
yes the type r tranny is perfect...
the B16 trannys are too weak; even for NA. Two of friends have broke b16 trannys on NA motors.
Yet to see a broken itr tranny from NA.
Old Jul 5, 2005 | 07:05 PM
Ketone's Avatar
Default Re: (Bk2fwd)
I see no con in getting a type R transmission! best modification i did for my car
Old Jul 5, 2005 | 08:34 PM
1whitedc2's Avatar
only con is that picking up a new itr tranny is bank$$$ picking up an used tranny is risky since a lot of retards don't know how to focking driving 5 spd and they fock up the synchro, otherwise itr is way better in terms of acceleration, and the LSD is a whole different world,
Old Jul 5, 2005 | 10:02 PM
apok's Avatar
Default Re: (1whitedc2)
It would be a good swap for the shorter gears. You might not like it though if your car is daily driven, due to the gas consumption.
Also, make sure you buy from a reputable source. As we all know, ITRs are raced a lot. The trannies have at least some wear due to racing. If they weren't properly maintained, they might not be as good of a deal as you believe.
The pros though are the LSD and shorter gearing for track racing. You'll lose your top speed though.
Old Jul 5, 2005 | 10:10 PM
phateless's Avatar
how possible is it to put a 6 speed tranny on a gsr? to me that extra gear takes out all the disadvantages of lower gearing. from the very first time i drove a civic si i thought "this thing desperately needs a 6th gear"
Old Jul 6, 2005 | 05:04 AM
Taristin's Avatar
Not possible.
Unless you spend 12k on a tranny.
Old Jul 6, 2005 | 06:17 AM
smkngsr's Avatar
Default Re: (Raa)
Im actually thinking of getting a USDM ITR trans or JDM ITR trans...i guess according to this thread its a very good choice...either or is win win choice tranny
Old Jul 6, 2005 | 06:32 AM
Spectrum24x's Avatar
Default Re: (smkngsr)
I got the B16 tranny in my Ls/v the short gearing is great, but im cruising borderline vtec on the highway, with a constant buzzing from the exhaust.
Old Jul 6, 2005 | 08:58 AM
Gearspeed-Performance's Avatar
Default Re: (Spectrum24x)
The B16 Hydro transmission has the same gear ratio as the Type R early models. Just use the GSR ring and pinion with a Type R LSD and you are set. If you have the money and a good source...get an original Type R and that will be just fine.
Old Jul 7, 2005 | 12:56 AM
DeeCeeTwo's Avatar
i just recently put a itr tranny into my gsr motor last weekend, feels good, i'm happy with it. if u got a vtec contorller you could proabbly just put the vtec higher. i heard some people put a ls 5th into a itr tranny for highway use.
Old Jul 7, 2005 | 03:35 AM
drussell4801's Avatar
Default Re: should I put a typeR tranny in my GSR (stixGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stixGSR &raquo;</TD></TR><TR><TD CLASS="quote">should I put a typeR tranny in my GSR</TD></TR></TABLE>
yes.
Old Jul 8, 2005 | 07:01 PM
. a d a m's Avatar
Default Re: (dc2vu)
all i was sayin is that with the prices of ITR tranny's at the moment ranging from anywhere from 900+ used...you COULD just get a b16 tranny used with a new LSD for about the same price...a shorter geared tranny will make a difference with a N/A motor</TD></TR></TABLE>
That's a good point. I wasn't really thinking about price...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bk2fwd &raquo;</TD></TR><TR><TD CLASS="quote">yes the type r tranny is perfect...
Yet to see a broken itr tranny from NA. </TD></TR></TABLE>
I actually heard this too, part of the reason why I don't like B16 trannies.
