94 LS air not working
Had that problem once, turns out to be a hit in parking lot cause the condensor pipe to burst, when the pressure drop below a threshold, it shut off the compressor to protect itself.
Bring it to a mechanic to put in a florecent dyed freon to check what happened.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear »</TD></TR><TR><TD CLASS="quote">Had that problem once, turns out to be a hit in parking lot cause the condensor pipe to burst, when the pressure drop below a threshold, it shut off the compressor to protect itself.
Bring it to a mechanic to put in a florecent dyed freon to check what happened.</TD></TR></TABLE>
kool, will do.
kool, will do.
Vt3c_eg
Aug 23, 2006 07:31 AM
