90 CRX SI no spark
It died at the end of the block. The engine turns over yet wont start fuel pump winds, and i can definetly smell gas. No spark is the problem, however i ran every test in the book crank sensor, igniter, and coil. All the fuses are also good. I had a code 3 for the map sensor prior to, but i reset it and also ran tests on it, but im not sure that would make it not spark. Any help would be great i dont want to spend a ton of money at a dealer for it to be something stupid. Oh yeah i also subed out a good ecu and no spark.
Modified by snapso_24 at 6:07 PM 7/4/2005
