Problem: Hella Horns Installation
Old Jul 4, 2005 | 01:37 PM
LsHoney84's Avatar
Default Problem: Hella Horns Installation
Considering that Im still learning about cars, this is my first time installing something electrical.
To others installing the hella horns was a piece of cake.
NOTE: Installation is done on a 95 integra.
My problem is the horn fuse (20A) keeps blowin. Can someone tell me if i installed the hella horns correct?
This is what i did:
1) Cut and removed stock horn.
2) Cut two 14 gauge black wires with identical length so I can connect the two horns together.
3) Connected the two identical wires to the connectors on the horns. I believe on the connectors of the horn it says a # 3 and # 38. Well I connected the wire from #3 to #3 and #38 to #38.
4) Bolted the 300 Hz horn on the driver side.
*Now its time to connect the two wires that came originally from the stock horn.*
I twisted the two wires together and made it into one wire. Since this wire is short I used a butt connector and took the left over 14 gauge wire for more length. At the end of this wire I used some crimp connector(the connector that has the circle on the end).
I attached this wire to the #3 terminal on the 500 hz horn.
5) Bolted the 500 hz horn on the passenger side.
NOTE: I did not use the relay because I read on all the other threads that you didnt need it.
Thanks for the help
Old Jul 4, 2005 | 01:40 PM
projectTeG's Avatar
where do you buy these horns from and what do they sound like? sry for the hi-jack its just that ive been seeing alot on them and i finally figure id ask
Old Jul 4, 2005 | 03:19 PM
JMD's Avatar
JMD
Default Re: Problem: Hella Horns Installation (LsHoney84)
You said that you twisted the 2 wires together from the stock horn to make 1 wire. I think that night be your problem right there. I had a similar problem with my spoiler when i twisted the 2 wires together from the stock spoiler and i had a fuse that kept blowing. Try untwisting them then see if it still blows.
Old Jul 4, 2005 | 07:47 PM
LsHoney84's Avatar
Default Re: Problem: Hella Horns Installation (JMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMD &raquo;</TD></TR><TR><TD CLASS="quote">You said that you twisted the 2 wires together from the stock horn to make 1 wire. I think that night be your problem right there. I had a similar problem with my spoiler when i twisted the 2 wires together from the stock spoiler and i had a fuse that kept blowing. Try untwisting them then see if it still blows.</TD></TR></TABLE>
Ill try that tomorrow morning. Im kind of confused. How did people connect the two stock wires from the stock horn to the new horn? Did you connect them separately each to their own terminal?
So if I connect the two wires separately one to the #3 connector on the horn and the other to the #38 connector.
NOTE This is being done on the 500hz horn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">where do you buy these horns from and what do they sound like? sry for the hi-jack its just that ive been seeing alot on them and i finally figure id ask</TD></TR></TABLE>
Look in the Misc & Appeance forums&gt;
Louder horns by Hella start at just $30.99. Brought to you by safedrives.com.
Old Jul 4, 2005 | 08:10 PM
Taristin's Avatar
The wires that are going to your horn, you tied together? I hope I'm reading that wrong, because if that's the case, you're causing a direct short, and that's why you're overloading your fuse.
Generally, you can connect all hot legs together, and all neutral (ground) legs (if you have to, I don't know the specifics of this install) but as soon as you connect a hot and a neutral you're asking for trouble.
Old Jul 4, 2005 | 08:17 PM
LsHoney84's Avatar
Default Re: (Raa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Raa &raquo;</TD></TR><TR><TD CLASS="quote">The wires that are going to your horn, you tied together? I hope I'm reading that wrong, because if that's the case, you're causing a direct short, and that's why you're overloading your fuse.
Generally, you can connect all hot legs together, and all neutral (ground) legs (if you have to, I don't know the specifics of this install) but as soon as you connect a hot and a neutral you're asking for trouble.</TD></TR></TABLE>
Thanks for teaching me something new. I really appreciate it. I didnt know that because Im still learning
Old Jul 5, 2005 | 06:11 AM
LsHoney84's Avatar
Default Re: (LsHoney84)
Is it ok to add 14 gauge wire to the two wires from the stock horn because they're not long enough? The two wires are a little bit smaller than the 14 gauge wire.
Old Jul 5, 2005 | 07:43 AM
dirtyrican987's Avatar
adding that wire shouldnt be your problem, it should be that you twisted the two wires together..... its kinda like when u hit jumper cables together positive + negative= short
Old Jul 5, 2005 | 08:27 AM
Taristin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for teaching me something new. I really appreciate it. I didnt know that because Im still learning </TD></TR></TABLE>
No prob. I do electrical work sometimes on side jobs, and find electrical problems the easiest to solve. Had my fog lights in and wired in a half hour.
But like LsHoney and I said, you're directly shorting your horns.
If you ever get one of those old screw-in fuses, like in the old buildings (the edison based fuses) and you put on in a lamp socket, and turn the lamp on, you'll see exactly what's happening. (Note I don't recommend doing that )
Old Jul 5, 2005 | 09:05 AM
LsHoney84's Avatar
Default Re: (Raa)
Thanks everyone. Im going to go and fix this right now.
Old Jul 5, 2005 | 09:39 AM
p nut's Avatar
Glad you got it figured out.
IMO, the FIAMM's sound a lot better than Hella's. Personally, I hate the "beep beep" sound, which the Hella Supertones still sound like--although they're louder than stock. I prefer a real car sound. (check the link for a sound clip)
https://honda-tech.com/zerothread?id=1186790
Old Jul 5, 2005 | 11:48 AM
Safe Drives's Avatar
H-T Basic Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks everyone. Im going to go and fix this right now.</TD></TR></TABLE>
Hi and sorry for the slow responce. We were out yeterday and justn ow chatching up on pm's and such. I just read through the thread and I think folks have you on the correct path now. If you still have trouble give me a call toll free 877-739-1713.
Thanks!
Charles
http://www.safedrives.com
Old Jul 5, 2005 | 07:01 PM
LsHoney84's Avatar
Default Re: (Safe Drives)
I fixed the problem. Thanks everyone for helping me out.
I followed illustration #1 on this link (didnt know these instructions existed).
These are great horns.
I tried it out in my garage...big mistake. They were HELLA LOUD. It made my ears ring and it echoed all the way out into my neighborhood everyone was lookin. HAHA.
So if anyone wants buy one, now you know a noobie can do it. Just got put some time and learn new things.
Wazup
Apr 18, 2011 04:04 PM
8dxhatchy8
22
Nov 1, 2009 12:25 AM
killercrx91
Audio / Security / Video
16
Aug 14, 2009 06:32 PM
messeduprex
Dec 16, 2008 07:13 PM
tgctruly
Nov 8, 2004 12:12 PM
