should i bleed brakes @ all wheels?
im the haynes manual it says i only have to bleed where i disconnected the brake line.... which would mean only where i changed my caliper, is this true? everyone i've asked even people at auto stores said i should bleed @ every wheel, i have drums in the back and discs in the front ... should i bleed the fronts since im changing the pads on the fronts? or should i bleed the fronts n back? thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95ej2 »</TD></TR><TR><TD CLASS="quote">You really should bleed all brake lines starting from furthest wheel from master cyl. to closest</TD></TR></TABLE>
No this is the wrong way on a Honda....I forgot what is the right way but I know this is wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">No this is the wrong way on a Honda....I forgot what is the right way but I know this is wrong.</TD></TR></TABLE>
no its not, thats how u bleed brakes on every car. dont say someone is wrong unless u can back it up
the whole bleeding the brakes thing has been covered many times...BUT to answer the original poster's question...when i changed my caliper when i still had stock in the front, all i had to bleed was the one i changed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">
no its not, thats how u bleed brakes on every car. don't say someone is wrong unless u can back it up</TD></TR></TABLE>
well actually it kind of is, you start furthest, closest, second furthest, second close
or in an EG back right, front left, back left, front right.
And to answer the question yes you have to bleed all lines of you will have air in them.
The manual tells you how to do it. Just do it like that and you will be fine. When I changed my caliper, I did them all. It is a better idea to do this.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 »</TD></TR><TR><TD CLASS="quote">back right, front left, back left, front right.</TD></TR></TABLE>
This is the proper bleeding order. Hondas use diagonal brake channels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 »</TD></TR><TR><TD CLASS="quote">well actually it kind of is, you start furthest, closest, second furthest, second close
or in an EG back right, front left, back left, front right.</TD></TR></TABLE>
really? i never did mine like that i have no problem.
i did mine back right, back left, front right, front left
thats how i was taught to do it and thats how i did it on my car and my friend did on his teg and no problems
And to answer the question yes you have to bleed all lines of you will have air in them.</TD></TR></TABLE>
this is correct for a dual diagonal system. I have done it all sorts of ways and it doesn't really matter. Unless you depress the caliper with the bleeder open you aren't getting all of the crap out of the caliper anyway. It takes on a different weight once contaminated and the clean fluid will flow right over the really nasty stuff.
As to the OP's question. If you clamp off the hose before you disconnect the caliper then youcan just bleed the one wheel. If the car could use it or you just let the hose drip then do them all.
HairyHarry
23
Oct 8, 2015 03:17 PM
Arvid
13
Aug 4, 2004 03:34 PM
