PCV valve? OBDII block OBDI head
Old Jul 4, 2005 | 10:13 AM
freakasis's Avatar
Default PCV valve? OBDII block OBDI head
what do i do about the pcv valve? my old motor had the black box on the back and the new block doesn't. i think the new ones have this valve in the head somewhere. so how do i put one on this setup? thanx.
Modified by freakasis at 11:34 AM 7/4/2005
Old Jul 4, 2005 | 03:10 PM
freakasis's Avatar
bump
Old Jul 5, 2005 | 06:51 AM
freakasis's Avatar
come one.no one knows this?....do i just need the obd ii valve cover? or would i need the whole head?
Old Jul 5, 2005 | 07:59 AM
Sack Master's Avatar
Default Re: (freakasis)
You just need the valve cover.
Old Jul 5, 2005 | 10:33 AM
freakasis's Avatar
thanx
Old Jul 5, 2005 | 10:47 AM
SlwGsr's Avatar
my pcv valve is under my intake manny
Old Jul 5, 2005 | 10:52 AM
gsrious's Avatar
you should really state as to which block... because the ls and crv motor have their pcv valve on the valve cover(only some years)...
Old Jul 5, 2005 | 11:02 AM
GoCarInteg's Avatar
Default Re: PCV valve? OBDII block OBDI head (freakasis)
my b20 has a PCV on the valve cover and i still have one off the LS manifold. what i did is just put the LS valve cover on it and no more worries of 2 PCV valves.
Old Jul 5, 2005 | 02:32 PM
freakasis's Avatar
gsrious, i thaught since i said obd II block and i also said that it had no black catch can, and this is the integra forum, that anyone who could answer my question knew that i ment a b18b block because the only other integra motor that is not type r is a b18c1 and they all had the oil catch cans...even the obd II ones i beleive. no one mentioned a b20...this is not the prelude or crv forum so if you dont know what i am talking about than that is your fault not mine...the only good answers that i got came from people who know what i was talking about.
JAPCIVIC R
Jan 7, 2004 11:02 AM
sander
Mar 16, 2003 08:23 PM
Ri5e
Mar 23, 2002 05:40 AM
Ri5e
Mar 4, 2002 05:08 AM
