Just installed rev hard turbo kit on my 92 si having problems
I wanted to know on delta waste gate there are two vac lines one on the side for the boost controller and one on top it says vac dont know what to hook that up to? I just have it t'ed off to one of my vac to my intake manifold.
It show im running lean but my lean but my fuel preasure shows 100 psi at my fuel filter i was wondering if it shows that because im running open header and i got my o2 relocated about 5 inches from the opening its a 4 wire o2 sensor idont know if thats the right one either please help.
ps other than that idles perfect no check engine lights just worried about running lean
Who is Mr Robot?
you leave the top port open... hook it up to the bottom port on the wg.
So i just leave the top part open
The other valve on the side of the waste gate is hooked up to my boost controller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmegsix »</TD></TR><TR><TD CLASS="quote">Imy fuel preasure shows 100 psi at my fuel filter i was wondering if it shows that because im running open header and i got my o2 relocated about 5 inches from the opening its a 4 wire o2 sensor idont know if thats the right one either please help. </TD></TR></TABLE>
Let me guess your running a FMU?
Very unsafe fuel pressure levels
mlyoung2
Oct 17, 2011 09:28 PM
