BRAKE PROBLEM HELP ME ASAP!!!
Old Jul 4, 2005 | 02:50 AM
jdmcivic1999's Avatar
Default BRAKE PROBLEM HELP ME ASAP!!!
i just finished swaping in my motor and i went to drive my car and found out my brake pedal takes alot of pressure to push down? its a really stiff pedal and was never like this. now could this be because i used an ABS axle for the passenger side during the swap? or is this totally something else? let me know asap what u guys think, ive researched it and found nothing. thanks for your time
Old Jul 4, 2005 | 03:09 AM
eXcelonTypeR's Avatar
Default Re: BRAKE PROBLEM HELP ME ASAP!!! (jdmcivic1999)
Try swapping it out for a non-ABS one, I don't have a definate answer, but theres a starting point
Bump for WA drivers
Old Jul 4, 2005 | 06:05 AM
pdiggitydogg's Avatar
Axle wouldnt do it.
Maybe you bent/crushed a hardline doing the swap
Old Jul 4, 2005 | 06:07 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivic1999 &raquo;</TD></TR><TR><TD CLASS="quote">i just finished swaping in my motor and i went to drive my car and found out my brake pedal takes alot of pressure to push down? its a really stiff pedal and was never like this. </TD></TR></TABLE>
Did you hook the vacuum line to the brake booster back back up? Did you use the original hose?
Old Jul 4, 2005 | 06:15 AM
egsleepercivic's Avatar
axles definately not the problem, I have abs axles in my non abs civic with no issues, like stated above check to make sure you didn't bend a hardline, and also make sure you hooked the vaccum back up
Old Jul 4, 2005 | 11:42 AM
Default Re: (egsleepercivic)
thanks guys for your help, i found out my friend hooked up the brake booster vacuum line up backwards, the arrow on the little plastic part was facing the wrong way. thanks for your guys help
miggy23
Dec 27, 2016 09:04 PM
gilbert90605
Mar 9, 2009 06:28 PM
jxhxb
May 10, 2008 10:30 AM
scorpio81
Jun 29, 2006 02:15 PM
