Installed New Sway Bar Today
Old Feb 14, 2002 | 11:04 AM
Flux's Avatar
Default Installed New Sway Bar Today
I tok some time to install a 23mm JDM ITR rear sway bar today and snapped a few photos along the way for those thinking of the ugrade. Install was very simple.
I took the car out for a short, spirited drive after the bar was installed - for those people that say you wouldn't feel a difference I have to disagree. I immediately felt the difference the bar provided - at some pont in the corner the back would come around way more than before. I'll give more of my impressions when I can drive the car in anger...
Stock bar (top) and JDM bar (bottom)
Stock (left) JDM (right)
Stock bar off
New bushings (left) vs. old bushings (right)
New bar installed
Old Feb 14, 2002 | 11:08 AM
Willard's Avatar
Default Re: Installed New Sway Bar Today (Flux)
bling bling
Will
-23mm wh0re
Old Feb 14, 2002 | 11:10 AM
B2FiNiTY's Avatar
Looks good. How hard is it to control the rear?
Old Feb 14, 2002 | 11:12 AM
sgT's Avatar
sgT
Default Re: Installed New Sway Bar Today (B2FiNiTY)
I wonder how much difference was due to the bushings and not the bar
Old Feb 14, 2002 | 11:15 AM
Flux's Avatar
Default Re: Installed New Sway Bar Today (sgT)
Good point. I don't know the answer...
Old Feb 14, 2002 | 11:25 AM
JPP's Avatar
JPP
On the JDM sway bars the bushings are OEM Honda and are the same hardness as stock. They just have a 23 mm hole to fit properly over the new bar.
The bar definitely reduces understeer.
[Modified by JPP, 3:37 PM 2/14/2002]
Old Feb 14, 2002 | 11:32 AM
H-PIMP's Avatar
Default Re: Installed New Sway Bar Today (JPP)
My car has H&R sports, JDM 23mm rear sway bar, and, JDM rear upper strut bar. ANd let me tell you. My car is the most rotateable ITR I've driven yet. to the JDM sway bar.
Old Feb 14, 2002 | 12:02 PM
SamB's Avatar
New User
Default Re: Installed New Sway Bar Today (H-PIMP)
OT: What kinda muffler is that??
Sam
Old Feb 14, 2002 | 12:04 PM
StageOne's Avatar
Default Re: Installed New Sway Bar Today (Sam & Bridget)
Comptech Muffler
Old Feb 14, 2002 | 12:07 PM
Flux's Avatar
Default Re: Installed New Sway Bar Today (StageOne)
Comptech Muffler
Thanks to Mike at IPS Racing for the bar...
Old Feb 14, 2002 | 12:08 PM
BSQ's Avatar
BSQ
A lot of people might think that a 1mm increase in diameter might not make that big of a difference. But, the 23mm JDM Type-R rear swaybar is 119% stiffer than the 22mm Type-R rear swaybar.
Old Feb 14, 2002 | 12:38 PM
Floyd's Avatar
Default Re: Installed New Sway Bar Today (BSQ)
Do you mean 119% as stiff, meaning a little bit stiffer, or 119% stiffer, meaning more than twice as stiff? (I'm getting a stiffy after saying the word "stiff" so much...)
Old Feb 14, 2002 | 12:39 PM
Willard's Avatar
Default Re: Installed New Sway Bar Today (Floyd)
19% more resistance to torsion.
Will
Old Feb 14, 2002 | 12:47 PM
yoshi234's Avatar
I shoot brides
Old Feb 14, 2002 | 01:05 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Installed New Sway Bar Today (yoshi234)
sweet, nicey nice
Old Feb 14, 2002 | 02:25 PM
beeboyee's Avatar
what are you going to do with the USDM version?
ill be snooping through your trash tonight ! lol
if you do throw it out, ill be happy to take it off
your hands!
Old Feb 14, 2002 | 02:33 PM
chiangm's Avatar
how did you come up with 19% more stiffer than the stock itr rear swaybar?
Old Feb 14, 2002 | 03:33 PM
BSQ's Avatar
BSQ
Default Re: Installed New Sway Bar Today (chiangm)
The swaybar stiffness can be expressed by this formula:
K = 1,125,000 (D^4) / L (B^2)
K is the rate of the swaybar in pounds per inch
D is the diameter of the swaybar
L is the length of the swaybar
B is the length of the swaybar arms (or moment arms)
Since the only thing that has changed is the diameter, you can take the diameter of the JDM Type-R rear swaybar and take it to the fourth power (23^4 = 279841). Then take the diameter of the stock Type-R rear swaybar to the fourth power (22^4 = 234256). Now divide the two amount to get the percentage of torsional increase ( 279841 / 234256 = 1.19).
BTW, thanks for correcting me Will (19% instead of 119%)
Old Feb 14, 2002 | 03:53 PM
Big Phat R's Avatar
Hmmmm - Mugen 26 mm rear bar = 26^4 = 456976/234256 = 1.9507547
95%....now <u>that's</u> a difference
[Modified by Big Phat R, 4:53 PM 2/14/2002]
Old Feb 14, 2002 | 10:23 PM
Fuminsho's Avatar
Default Re: Installed New Sway Bar Today (Big Phat R)
Hmmmmmm...... I wonder if that will fit on a del sol?!
Old Feb 15, 2002 | 04:20 AM
Dipshit Dan's Avatar
Default Re: Installed New Sway Bar Today (Fuminsho)
It wil but you have to reinforce your subframe or you'll tear it right out.
Old Feb 15, 2002 | 04:29 AM
2k1TypeR0610's Avatar
New User
Default Re: Installed New Sway Bar Today (God)
I thought this was discussed and the conclusion was reached that it would only tear out the subframe on civics and non type r integras? How do you reinforce the rear sub-frame?
[Modified by 2k1TypeR0610, 8:32 AM 2/15/2002]
[Modified by 2k1TypeR0610, 8:33 AM 2/15/2002]
Old Feb 15, 2002 | 04:30 AM
CPR's Avatar
CPR
Default Re: Installed New Sway Bar Today (2k1TypeR0610)
I thought this was discussed and the conclusion was readched that it would only tear out the subframe on civics and non type r integras?
A Del Sol is a civic
Old Feb 15, 2002 | 04:34 AM
New User
Default Re: Installed New Sway Bar Today (CPR)
Sorry didn't see he mentioned it was a del Sol.
Thanks
Old Feb 15, 2002 | 05:59 AM
BSQ's Avatar
BSQ
You can use a 22mm USDM or 23mm JDM Type-R rear swaybar on all '94-'01 non-Type-R Integras, '92-'95 Civics (all models), '93-'97 Del Sols (all models). They all share the same rear suspension subframe. To mount the Type-R rear swaybar properly (ie. to prevent subframe tearout) to the cars mentioned, you will need to mount the swaybar DIRECTLY to the subframe (which is exactly how the Integra Type-R's rear swaybar is mounted). To mount the swaybar directly to the subframe, you will need a Type-R rear swaybar mounting kit. The mounting kit reinforces the subframe sheetmetal and allows the be mounted directly to the subframe. You can go to my webpage at http://www.geocities.com/bretq/mounting_kit.html for further information on my Type-R rear swaybar mounting kit (aka. BSQ mounting kit). For step-by-step instructions for installing the Type-R rear swaybar, go to http://www.geocities.com/bretq/swaybar_install.html . The instructions also provide all of the parts (with Acura part numbers) and tools necessary for the installation, along with pictures. By following these instructions, you will not have any problems with subframe damage (ie. tearout).
You can also use the search function on the Integra forum and search on 'BSQ kit' or 'BSQ sway' and you can read a ton of information on this subject.
