need obd0 b16a distributor!
Old Jul 3, 2005 | 06:14 PM
JDMcrxb16a's Avatar
Default need obd0 b16a distributor!
I just a 90 crx si with the JDM b16a motor. Problem is... is that my distributor is bad. The guy who had it before me put a 88-91 civic distributor. I checked the coil and got a new cap and rotor but still nothin. So now I want the right distributor. Need one ASAP! e-mail me if anyone has one.
Old Jul 3, 2005 | 06:18 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: need obd0 b16a distributor! (JDMcrxb16a)
Try either of this places. They'll cost about 200.
streetimports.com or distributorking.com
Old Jul 3, 2005 | 06:20 PM
JDMcrxb16a's Avatar
Default Re: need obd0 b16a distributor! (mar778c)
Yeah streetimports sells them for 255 and distributorkings sells them for 285. I think I might just convert it to obd1 and go p28 ecu and just get it chipped? Would that be better?
Old Jul 3, 2005 | 06:52 PM
EF-21's Avatar
Hey i had the same prob. But i am poor so i used a 91 LS dizzy and cut off a leg. The only thing is that only one bolt will be held up its been working for about 8 months now. good luck
Old Jul 3, 2005 | 09:12 PM
NikoZai's Avatar
Default Re: need obd0 b16a distributor! (EF-21)
Get a LS b18 distributor and use it's internals. don't bother cutting a leg off, just use your housing with all it's parts.
Same shiznit different bolt pattern.
Oh and you've got one more part to replace The Igniter Unit. The most common part to die IMO
Old Jul 3, 2005 | 11:25 PM
Malgerus's Avatar
Default Re: need obd0 b16a distributor! (NikoZai)
I'm told the D16A6 distributor is the same (internally, won't bolt up) too.
RanCRX
14
Mar 21, 2011 11:48 PM
jedubz
Jul 15, 2005 08:46 AM
Tdemsko
Apr 7, 2005 08:20 AM
Jared
Jul 12, 2001 06:00 PM
