greddy profec b (not a honda)
Got a 00 toyota celica GT with a 1zzfe putting a turbo kit on it and bought a Greddy Profec B. Can't figure out where to put the hose to the fuel pressure reg. at. Not like a typical honda. its got the hard fuel line to the fuel rail and the regulator sits in the middle of the rail with no vacuum attached. Thinking maybe a solenoid to a line under the car? like a 2jz or mits. motor. Thinking anyone with a techs manual or computer program could look. Any thoughts welcomed and appreciated.
Who is Mr Robot?
you dont hook anything up to teh fuel pressure regulator... the profec b is a boost controller. you hook it up between the wastegate and the intake manifold
the instructions said the vacuum line to the regualtor as well as between the wastegate and the manifold. im not touching the actual fuel lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">the profec b is a boost controller. you hook it up between the wastegate and the intake manifold</TD></TR></TABLE>
Like he said use any vaccum source. That's what I did and it works great.
civiclxb16a
13
Mar 24, 2005 02:57 PM
