Headlight positioning..
Old Jul 3, 2005 | 02:27 PM
Agent STFU's Avatar
Default Headlight positioning..
I don't know if you guys have had this problem before, I did a search and didn't find anything..
My driver's side headlight is not flush like my other side. It sits a little bit inwards, and up. It also points up, and is very blinding to the other drivers in the oncoming lane, I'm sure.
The screw on the top, when I loosen it, the headlight does not move forward, like the other side. If I pull it forward, it just falls back, and is really loose unless I tighten it up. Then it doesn't sit flush, at all. Iis there some other bolts that may be adjusted?
I was driving home the other night, and everyone I passed was flashing their brights at me, so I don't want to keep blinding the oncoming lane...
Old Jul 3, 2005 | 03:10 PM
civic_dork's Avatar
Default Re: Headlight positioning.. (S Y Z L E)
The little plastic insert/nut often cracks/breaks and has similar effect to what you're saying... sorta. Are yours in good shape? both of mine were broken, and took about 5 different cars to find 2 that came off in good shape at the junkyard.
Old Jul 3, 2005 | 03:12 PM
Agent STFU's Avatar
Default Re: Headlight positioning.. (civic_dork)
You mean the piece the screw goes through?
I'd have to go look at it, I'll take a look and let you know, thanks!
I'll pull all the mounting hardware off another EF if I can ever find one in a junkyard.
EDIT: Thanks for your input
Old Jul 3, 2005 | 06:14 PM
fkguitar's Avatar
I don't even have that little plastic piece on my passenger side headlight. Can you get them from majestic?
patrickstar
Feb 6, 2009 10:33 PM
jacksonww
Oct 5, 2008 08:16 AM
otsegolectric
Jul 22, 2008 10:47 AM
HaRrYbOy
Honda Motorcycles
Jan 2, 2006 09:45 PM
slvrcivic97
Apr 12, 2003 11:23 AM
