my teg wont start
wsup little help needed here.......!! i have a 94 ls and sh#$t wont start... it will crank and thats all it will do... i checked made sure the spark plug wires are throwing sparks and new plugs were just put in... o yea no engine check light is thrown... it sounds like the gas isnt getting tot he engine like it sounds like it is trying to turn on but theres no fuel there... i just bought fuel injector cleaners and im trying that... any word of advised to try next..... if you need more info ask me... cause i think thats everything
Ok take one of the spark plug out of the motor. Attach it to the spark plug wire. Hold it and ask some1 to crank the motor for you. If it spark than you have spark. That mean the Distrubutor and spark plug are fine. Next Turn you key in the ignition over but not start, Listen for a bzzzz sound comming from the Middle Back seat. If you hear it than the Fuel pump are probably ok. Check the Fuel Filter might be dirty or clog. Check the Fuel injectors. Cars need 3 thing in order to start. 1. Fuel 2. Spark 3. Air
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda1982 »</TD></TR><TR><TD CLASS="quote">Ok take one of the spark plug out of the motor. Attach it to the spark plug wire. Hold it and ask some1 to crank the motor for you. If it spark than you have spark. That mean the Distrubutor and spark plug are fine. Next Turn you key in the ignition over but not start, Listen for a bzzzz sound comming from the Middle Back seat. If you hear it than the Fuel pump are probably ok. Check the Fuel Filter might be dirty or clog. Check the Fuel injectors. Cars need 3 thing in order to start. 1. Fuel 2. Spark 3. Air</TD></TR></TABLE> Yeah and make sure there are no sock or **** like that shoved in your intake, j/p. Yeah listen for the buzz mentioned and check for spark to be 100% sure. let us know what happens and what you did.
fooboo
May 22, 2010 01:53 PM
