Need help from you fellow B16'ers
ok here is the thing i just recently got a cold air for my b16 but now i landed in a little bit of trouble. its probably already been discussed before but i didnt find anything so i was hoping u guys could help me. i want to know what i have to do with the 2 vaccum hoses that are no longer connected to the intake ? do i T them to some other ones, leave them loose or what ??? hopefully somebody can help me. if u guys need a pic of what im talkin about let me know so i can post 1 up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">the CAI should have two nipples on it to connect them.
Nope
</TD></TR></TABLE>Nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">cap them off, see what happens.</TD></TR></TABLE>
how would i cap them off ???
One is a breather vent from the valve cover and the other is a coolant line. You can get a breather filter from Autozone or somewhere and the other one you can run a new hose so you can get rid of the metal black ones that are connected together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Synister »</TD></TR><TR><TD CLASS="quote">
how would i cap them off ???</TD></TR></TABLE>
Yes, you can cap them off. That is what I did, I just put in a screw in both of the hoses and no problem
I dont have a digital cam, or else I would of taken pictures of it, so you can see what IAm talking about.
You have one that is for the breather and one from the EGR . You can reroute the EGR one to anywhere that has vaccuum. But to get rid of that messy **** , buy another coolant hose and run it from the motor to the throttle body. Makes it look alot cleaner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx »</TD></TR><TR><TD CLASS="quote">You have one that is for the breather and one from the EGR . You can reroute the EGR one to anywhere that has vaccuum. But to get rid of that messy **** , buy another coolant hose and run it from the motor to the throttle body. Makes it look alot cleaner.
Have any pics ?
</TD></TR></TABLE>Have any pics ?
B16's don't have EGR, one is for the throttle body dash pot, the other is PCV, you'll want to figure out a way to hook the PCV back up, but don't worry about the dashpot, it just makes the throttle close a little slower right before it snaps "shut".
Also the coolant lines you guys are thinking about run through the throttle body, not the intake arm.
</TD></TR></TABLE>B16's don't have EGR, one is for the throttle body dash pot, the other is PCV, you'll want to figure out a way to hook the PCV back up, but don't worry about the dashpot, it just makes the throttle close a little slower right before it snaps "shut".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6 DOHC ED9 »</TD></TR><TR><TD CLASS="quote">Have any pics ?</TD></TR></TABLE>
I AGREE WITH 1.6 DOHC ED9
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6 DOHC ED9 »</TD></TR><TR><TD CLASS="quote">Have any pics ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Synister »</TD></TR><TR><TD CLASS="quote">I AGREE WITH 1.6 DOHC ED9</TD></TR></TABLE>
There is no EGR... I've done so many b16a swaps I wouldn't wanna count, trust me... there is no EGR.
Don't know why the hell i said EGR (i meant dashpot), but anyway, To keep it clean i'd find a new vaccuum source for it, and just put a breather on the PCV. Run a new coolant line to get rid of the stock lines that are welded together. I've done so many that i'm starting to forget ****!lol
well since u guys are getting confused i just decided to post a pic of what im talking about. i have circled what hoses im talking about that are no longer going to im intake because i got the cold air. so what do i do with them ?
Cap them off. Nicest would be to weld them shut, but glueing a wide self tapping screw in will work fine as well.
Remember to let the glue dry before starting the engine. (mentioning just in case)
they are dashpots.. they are used for sudden stops .. and also for stop and go traffic.... i just took them off .,. the only one u need to worry about is the one that on the right. Thats the only one that has any vaccum on it.... the left one runs off vaccum from the intake tube.... i think that is how it goes... correct me if im wrong..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guywitaDA »</TD></TR><TR><TD CLASS="quote">they are dashpots.. they are used for sudden stops .. and also for stop and go traffic.... i just took them off .,. the only one u need to worry about is the one that on the right. Thats the only one that has any vaccum on it.... the left one runs off vaccum from the intake tube.... i think that is how it goes... correct me if im wrong..</TD></TR></TABLE>
yes the one on the right you can cap go any parts store autozone,pepboys,ect. and go to the help section they will have little black caps put one on the right that is circled the you dont even need just take the hose off and you will be fine trust me
From: hittin corners so hard you can taste my rims..
the both of those are used for idle advance for the AC... chances are your car doenst' have AC anymore.. so use a vacuum cap, and cap it off.
AspectIndustries
Welding / Fabrication
199
Jan 13, 2011 05:37 PM
