Tanabe SMR cracked.. NEED HELP!
Old Jul 3, 2005 | 11:22 AM
Nick97hatch's Avatar
Default Tanabe SMR cracked.. NEED HELP!
97 Hatch-Back,
I found a crack in my tanabe exhaust today . It cracked in the "S" Shaped portion of the exhaust. (In front of the muffler, but back from the header) I am wondering if I can buy just the cracked section. I have been searching here and the web but not having much luck.
Any one know were to look? Also about how much $$?
Nick
Old Jul 3, 2005 | 12:42 PM
e jay one's Avatar
Default Re: Tanabe SMR cracked.. NEED HELP! (Nick97hatch)
whats it made out of? you might be able to take it to a muffler shop and get it welded. or even have them make a new peice.
Old Jul 3, 2005 | 12:53 PM
komat's Avatar
Default Re: Tanabe SMR cracked.. NEED HELP! (e jay one)
a muffler shop can either weld it or repart that section that is cracked with a new pipe
Old Jul 3, 2005 | 03:16 PM
nub.96ek's Avatar
Default Re: Tanabe SMR cracked.. NEED HELP! (komat)
I hear about this happening to Tenabe exhausts all the time... hatchlessREX's did it like 3-4 times before he finally said screw it.
Old Jul 3, 2005 | 05:20 PM
It's stainless, It is made of a thin wall tubing so can it be re-welded? If so will it just crack again at the welds? Also about how much is it to have a new pipe made? Will it flow as well?
Thanks
NICK
Old Jul 4, 2005 | 12:31 AM
eXcelonTypeR's Avatar
The weld shouldn't crack if you just get it re-welded where it cracked. The weld should be stronger than the metal being welded. So if it cracks in front or behind the weld then it might just be shitty metal and bad luck, but if the weld itself cracks then the welder needs more practice.
If you just have them weld in a new pipe have them use one size bigger piping if a bend has to be replace, if not just use same size pipe.
Old Jul 4, 2005 | 09:29 AM
Cool, Thanks for the help guys!!!
NICK
hondafdj444
Feb 13, 2014 06:33 PM
chiaxi2002
Aug 5, 2009 12:58 PM
TTM
Oct 14, 2005 02:12 PM
xmr. robotox
Welding / Fabrication
Mar 2, 2005 02:30 PM
redman223
Jan 4, 2003 12:56 AM
