how many shot cant a b18c cant handle?
there is my 2 setup idea #1 b18c whit b18a piston whit a 3 layer gasket (to get +-9.5CR)+335cc injector +a 255hl fuel +a fuel regulator
#2 b18c +335cc injector +a 255hl fuel +a fuel regulator
how many shot of NOS should i spray in (direct port system 4fogger)for a safe use
dont look my english an french
thank you
[Modified by b16a 2 b18c, 6:50 PM 2/14/2002]
thank you
You just need to make your set-up as safe as possible and you won't have a problem spraying 100shot. I've seen a dual stage 120shot setup on a stock GSR. It was a 60 shot plate and then a 60shot wet on top of that.
Use a fuel pressure cut-off switch, msd ignition with soft touch, run colder plugs, an msd window switch, and best of all, take as pass on the dyno with a good a/f guage, to make sure your running stoich on spray. With the direct port you can adjust each fuel and nitrous individually so you can setup the perfect nitrous/fuel mixture for your setup.
KCDelSol
Jan 19, 2004 08:56 PM
