Engine Replaced noe Burning Oil
Old Jul 3, 2005 | 07:23 AM
vicarnes's Avatar
Default Engine Replaced Now Burning Oil
My nephew relaced the 1.5 engine in son's '92 Civic Hatchback. Now it's running great but burning oil. Tail pipe is really black. It blows black smoke on accelleration, gear-shifting, etc. ... but seems to run smoth. We have it parked til this is resolved. Tear in plastic timing belt cover gives me access to swab for oil... appears to be dry. Torn/blown oil seal? Advise??? Thanks.
Modified by vicarnes at 9:35 AM 7/3/2005
Old Jul 3, 2005 | 08:25 AM
paulbeezie's Avatar
Oil in tailpipe? or just black? could be running too rich and washing rings. Ck coolant temp sensor and PCV valve.
Old Jul 3, 2005 | 08:31 AM
vicarnes's Avatar
Default Re: (paulbeezie)
Just black smoke (dry at tail pipe, no wet oil). Pcv good. Temp great. Thx
Old Jul 3, 2005 | 08:40 AM
EK45VTi's Avatar
Default Re: (vicarnes)
How much oil is it burning...
A small amount of black gunk on tail pipe is normal...
And when it smokes during shfting or acceleration, which color is the smoke? White, Blueish or black?
White - burning coolant
Black - running rich
Blueish - burning oil
Old Jul 3, 2005 | 08:43 AM
vicarnes's Avatar
Default Re: (KKVTi)
I'll check a bit later today and update. Gotta run. You guys are great!!!!
Old Jul 3, 2005 | 08:47 AM
fastrunner's Avatar
try some sea foam you may just be burning off residual oil depending on how the engine was stored.
Old Jul 5, 2005 | 03:03 PM
vicarnes's Avatar
Okay, here's the update. We changed the PCV valve and the hose (was really gunked inside). Cranked it up. Runs smooth. But, still blowing light grey/bluish smoke. Coolant level is great. Doesn't run hot. Runs smooth. Burning oil, right? Piston rings? Before we tear the engine apart... Can it be anything else? Thx.
Old Jul 5, 2005 | 03:11 PM
CXified's Avatar
it could be the valve seals, thats what it turned out to be in my hatch and it was showing the same symptoms you are describing, who knows
robbys89
Aug 25, 2009 07:09 AM
k20chornicalz
15
Dec 19, 2008 04:34 PM
818blue818
Nov 2, 2008 11:15 PM
Takymoto
Nov 22, 2005 02:29 PM
citanest
Oct 18, 2001 09:27 PM
