Just read this!!
I didnt know what forum to put this is so i figured sound would be the best. Im doing a lot of **** to my car in the next few months but when its done i want the inside to be as quiet as possible with no road noise (i know dynamat will do) but i also wanna kinda "tighten" is up...? if anyone knows what i mean. Its a 96 prelude but **** just feels loose, like when i shut the doors, or when i start to pull out of first gear or sometimes when im even idling i get a wicked shaking. If thers any type of material or foam you could use or anything i could do to stop it lemme know. Thanks.
link http://www.dynamat.com they have all sorts of things, not just "dampening" material, "rattle" control also, and ordinary foam weather strip can do wonders
94
94
You'll need a lot more than Dynamat to fix all the "loose" stuff.
Replace engine mounts. Don't use urethane unless you want your entire car to vibrate all the time.
Replace shift linkage bushings
That will take care of the two you just mentioned.
jazz215
Jan 27, 2004 08:28 PM
