Swap is done.. car wont start!
I finally finished my swap.. but the motor wont start.. it turns over fine, but it just doesnt fire up. Heres the diagnosos: Checked for spark in the #1 plug wire.. NO SPARK.. checked to make sure fuel is getting to the fuel rail.. sure enough. It seems to be that there is no spark to ignite to motor.. ANY SUGGESTION?? i need the car for a date.. thank you in advance..
yea you could check the grounds, when i first did my zc swap i had a bad ground and went through 4 ignitors
, but the car started then died when it got hot, i would swap out the ignitor and coil if you got extras, if not borrow one of your friends distributors
quicker if not easier than testing the coil and ignitor.
99sonicbluegsr
Sep 27, 2004 10:35 AM
