Integra Rear Suspen Bolt Shearted Off !!NEED HELP!!
Old Jul 2, 2005 | 08:26 PM
onemoreday21's Avatar
Default Integra Rear Suspen Bolt Shearted Off !!NEED HELP!!
I was installing shocks and coilovers. When removing the bottom mounting bolt on the right rear shock the bolt head sheared off and the nut at the other end is permanently fixed on the trailing arm. I cant get anything near it to get it off.
Anyone know any good ways to remove the bolt so I can put in my new suspension? I need help very fast!!
Old Jul 2, 2005 | 08:39 PM
gsrious's Avatar
Default Re: Integra Rear Suspen Bolt Shearted Off !!NEED HELP!! (onemoreday21)
use a screw extractor... fisrt drill into the broken bolt then screw it out.
Old Jul 2, 2005 | 08:40 PM
98b18black's Avatar
Default Re: Integra Rear Suspen Bolt Shearted Off !!NEED HELP!! (gsrious)
This is quite a common problem I hear... Happened to me...
Old Jul 2, 2005 | 08:44 PM
TrueUntilDeath.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">use a screw extractor... fisrt drill into the broken bolt then screw it out.</TD></TR></TABLE>
aka, easy-out
Old Jul 2, 2005 | 08:55 PM
2nd_Gen's Avatar
happen to me 2...****...the thing is that i drove on it for a while..and my shock started to bend a lil...where the fork rests on the control arm. i tryed to drill it and screw it out..but my bolt was frozen...and the more i tried to take it out..the more my shock was bending.
i took it to a local shop and it cost me 40 bucks. when the bolt came off...the bushing was fucked...so i had to get new ones...
they told me that i had to heat it up with a propane torch so it looses up the bolt and then reweld the bolt head to the bolt and unbolt it out...
civicdelsol33
Suspension & Brakes
Dec 17, 2007 09:45 AM
2Point2EH2
Apr 25, 2006 10:36 PM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
GoQkRaCeR
Apr 24, 2004 05:40 PM
_Shadow_
Aug 28, 2002 04:55 PM
