what way to turn dixxy for advanced timing
Old Jul 2, 2005 | 07:45 PM
the.hamburglar's Avatar
Default what way to turn dizzy for advanced timing
all the colors are shot but i can still make use of the 3 groovs. since i cant see the colors i need to know what way to turn the dizzy to advance my timing
Old Jul 2, 2005 | 08:02 PM
HuntsvegasHatch's Avatar
Default Re: what way to turn dizzy for advanced timing (hamburgler)
you rotate it towards the rear for advance (towards Intake Manifold) towards the front for retard. Hope that helps.
Old Jul 2, 2005 | 09:29 PM
Default Re: what way to turn dizzy for advanced timing (HuntsvegasHatch)
ok thanks, i cant see an arrow like some instructions say but i did find a small groove that looks like it could be the arrow because the color bars on the crank pully were really close.
Old Jul 2, 2005 | 09:51 PM
Crasian's Avatar
yeah, the groove in the timing belt cover is what u use to check your timing...
Old Jul 2, 2005 | 11:02 PM
Default Re: (Crasian)
i guess the b16a doesnt have a so called arrow. what should you do when the paint is all gone for the degrees
Old Jul 3, 2005 | 06:40 AM
shoot from the hip and pray? no really just tune moderatly and drive it to see if you get the results you want. If not keep tuning.
Old Jul 3, 2005 | 06:41 AM
BTW depending on your car you made need to jumper the diagnostic plug while tuning otherwise the ECU will correct anything you change and then you are just wasting your time
Old Jul 3, 2005 | 07:42 AM
yeah did this all, car pulls better at 16 degrees than advanced to 18 degrees. any reason for this? i followed c-speedracing.com instructions
Old Jul 3, 2005 | 07:48 AM
oh also when i jumped the diagnostic wires i got a code 20 on the dash
88-98 Civic
97-98 CRV
92-98 Prelude
94+ Integra Electrical Load Detector defective circuit or unplugged / defective sensor
unplugged it and the code went away. weird
Old Jul 3, 2005 | 12:48 PM
probably an old code. As for 16 vs 18 what kind of setup are you running with what modifications.
Old Jul 3, 2005 | 02:44 PM
just an intake, not cold
Old Jul 3, 2005 | 02:45 PM
that old code doesnt show when its not jumped and my engine light is not on
Old Jul 3, 2005 | 04:52 PM
sometimes codes don't show but are stored in the ecu (not cleared yet) and why are you doing the timing advance just for an intake?
Old Jul 3, 2005 | 07:20 PM
i just advanved it to 18 degrees to see if it made any difference and i didnt. it made the car run worse. so its about 17 degrees right now but obviously its hard to tell. my intake really only consists of cotton over the throttle body. bad idea i wouldnt recommend it
1mistashank
May 29, 2009 08:17 PM
killacam661
Jun 28, 2008 09:13 AM
brokenojoke
Engine Management and Tuning
Jun 14, 2008 09:50 PM
aron0903
Aug 4, 2004 12:34 AM
neumonik
Mar 10, 2002 04:41 PM
