Will Hmotors swap shift linkages when purchasing an engine?
I am purchasing a GSR complete swap from hmotors on Tuesday and wont be able to get ahold of them until then (closed on 4th of July). I just wanted to know from any of you that have dealt with hmotors, will they be able to give me a Del Sol VTEC shift linkage instead of the GSR shift linkage that comes with the swap?
One more question:
Will the stock GSR motor mounts that come with the complete swap from hmotors work with the Del Sol or do i need to purchase different ones?
Thanks!
One more question:
Thanks!
if they dont
just ask steve to work something out with you
hes a reasonable man if u are nice to him
the motor mounts will work
they dont give u the torque mounts you will need to reuse yours from your civic/delsol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryro22 »</TD></TR><TR><TD CLASS="quote">uuhh..dont know that i understood your reply
Can anyone give a clear answer to my questions???
Thanks!
You will when you pull your motor.
Thanks!
Sorry Komat I didnt see that you already said the mounts will work.
Thanks for the info...I will search more before posting.
do u have a del sol vtec? if so, then (from what i understand, its a b16 and b series parts, for the most part, can be interchangeable from what i heard
) the mounts should work.
EDIT: ^ beat me to it
) the mounts should work. EDIT: ^ beat me to it
mish__
Mar 18, 2011 05:13 PM
NZDelsoldude
Feb 15, 2009 01:58 AM
90civichb
Jun 5, 2004 04:13 AM
