HELP!! PLEASE, Doing VALVE Adjustment on SOHC
Old Jul 2, 2005 | 05:12 PM
suspirocrx's Avatar
Default HELP!! PLEASE, Doing VALVE Adjustment on SOHC
hi :D
Im trying to make the valve adjustment, but i have a doubt, where should i place the feeler gauge and measure.. please
thnkx
thnkx
Old Jul 2, 2005 | 05:24 PM
suspirocrx's Avatar
Default Re: HELP!! PLEASE, Doing VALVE Adjustment on SOHC (suspirocrx)
bump!
Old Jul 2, 2005 | 05:30 PM
suspirocrx's Avatar
i have checked the manual, but its not very clear about that point...
thnkx
Old Jul 2, 2005 | 06:07 PM
vtecn8ive's Avatar
Default Re: HELP!! PLEASE, Doing VALVE Adjustment on SOHC (sam385)
You place it in between the valve stem and the rocker arm. Make sure the specific cylinder is at TDC.
JUST GIVE THE GUY ADVICE
Old Jul 2, 2005 | 06:44 PM
sam385's Avatar
Default Re: HELP!! PLEASE, Doing VALVE Adjustment on SOHC (vtecn8ive)
if one doesn't use the procedure in the honda shop manual, things can get really screwed up
that's all i'm sayin' here, man
wouldn't you consider that sound advice?
Old Jul 2, 2005 | 07:05 PM
fireant's Avatar
use the smallest size blade, and you'll quickly find the only spot it could go in.
nice close-ups by the way. I swear you can see a person reflected in the oil on the cam in this pic.
Old Jul 2, 2005 | 09:20 PM
suspirocrx's Avatar
Thnkx a lot
I did my valve adjustment and everything was so nice!!
and idle and run super smooth!!!
thnkx guys!!!
Old Jul 2, 2005 | 10:05 PM
91zSi's Avatar
Default Re: (suspirocrx)
fireant,
Excellent pic.!
Sure that the reflection is a person?! or a ghost?!
tony_yang
Oct 13, 2010 08:12 PM
HatchSpeeD
Jul 5, 2005 01:29 PM
mymeatb18"
Dec 27, 2004 11:54 PM
b18prl
Mar 26, 2003 11:21 AM
ZUL8R
May 8, 2002 01:06 PM
