CV problems
Old Jul 2, 2005 | 04:41 PM
:mR. PotAtO heaD:'s Avatar
Default CV problems
i was in the process of replacing the passenger side CV halfshaft on my 89 rex and i ran into a snag.. i got the old 1 out and started 2 put the new 1 in but it wont go in all the way nor come back out... why is this?
Old Jul 2, 2005 | 05:30 PM
sam385's Avatar
Default Re: CV problems (Lilstreetracer88)
there are different CV axles for the same model civics/crx. they are slightly different in length and have a different number of spline teeth on the ends of the shafts. you should see some colored stripes of the shaft to denote the correct one for your car. hope this helps.
Old Jul 2, 2005 | 06:15 PM
Default Re: CV problems (sam385)
i didnt kno that but my problem now is i cant get it out.. its like its jammed in there.. iv tried everything and idk what else 2 do
Old Jul 2, 2005 | 06:19 PM
Bunger's Avatar
Is it stuck in the trans or the hub?
Old Jul 2, 2005 | 08:01 PM
Default Re: CV problems (Bunger)
the trans
Old Jul 2, 2005 | 09:00 PM
Bunger's Avatar
Humm, well, if its not all the way in you should be able to use a pry bar to GENTLY pry it out. Check to make sure the splines are clean and straight, it should slid in fairly easily and the C clip will hold it in place. Be sure to check the condition of the C clip, its not uncommon for rebuilt axles to come with used, tired C clips.
Rhymenoceros
Nov 19, 2007 07:22 PM
2wheelhunter
Jan 21, 2007 08:23 PM
Sehc Tib Alli Zerif!!!!!
Apr 18, 2006 01:15 PM
type Gendy
Aug 7, 2004 03:09 PM
Kasper.
Jan 31, 2004 12:28 AM
