nitrous jets zex dry kit
ok can some one tell me where the nitrous jets are located at on a zex dry kit. i know there is 2 of them and i think one goes in the big fitting on the box labeled nitrous in inbetween the fitting and the sylonoid thing and the other goes between the nozzles and the line going in the intake is this correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">ok can some one tell me where the nitrous jets are located at on a zex dry kit. i know there is 2 of them and i think one goes in the big fitting on the box labeled nitrous in inbetween the fitting and the sylonoid thing and the other goes between the nozzles and the line going in the intake is this correct?</TD></TR></TABLE>
Almost.
One goes in the barb fitting on the box labeled "INTAKE". It's the outer port on the box. You can remove the fitting with a wrench and put in your appropriate "fuel" jet.
The second jet goes in the nozzle that sprays into the intake. This is your "nitrous" jet.
Otherwise, HERE is the instruction manual from ZEX's site. You'll need Adobe to open it.
Good luck! Remember to start off with the smallest shot then move up if you need to. I wouldn't go more than 75hp on a dry kit.
Almost.
yea i dont have adobe to open that and i am going to start with the 55. but are you sure the fuel jet goes in the fitting intake? this is the vacum fitting right. it looks like it would go into the one that says nitrous in. ill take another look. thanks
Curtis2kul
12
Mar 19, 2004 12:24 PM
