Simple front crossmember question
Old Jul 2, 2005 | 04:03 PM
crexer's Avatar
Default Simple front crossmember question
Getting ready to drop my front crossmember to take off my dc 4-1 header to sell and I was curious if after dropping this and removing the radius rod bolts if it screws up the front alignment since I just had it done.
Old Jul 2, 2005 | 04:52 PM
Cory man's Avatar
Default Re: Simple front crossmember question (crexer)
If it makes any minute change it wont be noticeable to you or make your tires wear. Bolt it up and go.
Old Jul 2, 2005 | 04:59 PM
bspeed's Avatar
nope. if you only drop the Xmember and unbolt the radius rods from the lca's there will be ZERO change, provided your car is straight and you aren't removing bent bolts.
Old Jul 3, 2005 | 05:17 AM
crexer's Avatar
Default Re: Simple front crossmember question (bspeed)
apprciate you fellas
jrivehard
May 9, 2008 11:51 PM
crxrace
Mar 21, 2006 04:47 AM
NumberB
Mar 21, 2005 09:38 PM
94DOHCDELSOL
17
Jan 19, 2005 03:50 PM
GradyDC5
Nov 8, 2004 01:25 PM
