92 Civic hatch - TYPE R D brackets - NEED ANSWERING!
Old Jul 2, 2005 | 03:44 PM
piatl7il77's Avatar
Default 92 Civic hatch - TYPE R D brackets - NEED ANSWERING!
can I straight bolt on a stock integra type R rear sway bar and D brackets onto my 1992 Civc hatch frame?
if not is the beaks kit suppose to solve this problem or is the beaks kit just suppose to prevent frame tearing?
Any info would be appreciated...
Old Jul 2, 2005 | 03:52 PM
cxSHOE's Avatar
Default Re: 92 Civic hatch - TYPE R D brackets - NEED ANSWERING! (piatl7il77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piatl7il77 &raquo;</TD></TR><TR><TD CLASS="quote">can I straight bolt on a stock integra type R rear sway bar and D brackets onto my 1992 Civc hatch frame?
Any info would be appreciated... </TD></TR></TABLE>
if you have holes on your rear lca's (94+integra lca's) then yes you can bolt up the sway bar, and the beaks kits is just to add more support to the lower frame. i use the cheaper bsq kit and it works just the same and is cheaper. look in the suspension section for a debate between the two..
Old Jul 3, 2005 | 10:01 AM
piatl7il77's Avatar
but how come when I tried bolting up the type R D brackets up to my civic....only the top bolt fits because the length of the D bracket holes are farther apart then on the Civic.
or am I just bolting them on wrong?
AK94GSR
Jul 31, 2006 11:01 PM
sc_92_civic_hatch
Jan 26, 2004 11:47 AM
plusONE jboy
Nov 27, 2003 11:16 AM
KRiS1
May 20, 2002 04:21 PM
donkeypunch
Mar 28, 2002 03:43 AM
