vss (speed sensor)
Old Jul 2, 2005 | 12:16 PM
LudeJdm's Avatar
Default vss (speed sensor)
ok i replaced the vss and changed the cluster and still nothing....should i replace the speedo cable...or do i have a bad tranny....wut should i do...also when i replaced the vss...there was oil in it....do you think that theres oil in the speedocable and its causing it not to spin???
still getting code 17 and speedo still dont work
Old Jul 2, 2005 | 12:30 PM
90civichbsi's Avatar
Default Re: vss (envysionHATCH)
alot of times all it is going to be is the speedo cable they get stretched out and snap after a while, just take it off and twist one end and hold the other with your hand.. if both sides dont turn when you twist one side its broken.
Old Jul 3, 2005 | 05:45 PM
LudeJdm's Avatar
Default Re: vss (90civichbsi)
does anyone think that i got oil into the speedo cable???because when my friend took out the vss oil was in it and it was a lot....like it was dripping down...i know it should be lubed but not that much....so should i go ahead and replace the speedo cable????
Old Jul 3, 2005 | 05:54 PM
egtwincam's Avatar
there is lube for the cable but more doesn't prevent it from working. its either the speedo, cable or vss. those are the only components.
The most likely cause that most people make the mistake of is installing the cable into the vss....make sure the cable is actually in the notch and clip is on correctly.
Old Jul 3, 2005 | 06:02 PM
stockbee's Avatar
in response to what egtwincam said, YES it is a very good thing to make sure your speedo cable is actually in the notch. I don't mean to repeat what he just said, but i had an experience where my cluster didn't work for about 2 weeks (no speedo, no vtec, no odometer either), and I finally took it out, and pushed it in there (all the way that time), and it worked. most likely vibrated out on the way down to FL.
Old Jul 12, 2005 | 06:18 PM
LudeJdm's Avatar
Default Re: (stockbee)
ok installed a new speedometer cable...and finally everything works...speedometer works...vtec works....but!!! im still getting code 17...why is that????
Old Jul 12, 2005 | 07:41 PM
cbrodac0424's Avatar
Default Re: (envysionHATCH)
you need to reset your ecu to do that disconnect the neg battery cable or just pull the ecu fuse.
Old Jul 12, 2005 | 07:44 PM
LudeJdm's Avatar
Default Re: (cbrodac0424)
i did that still code 17
Old Aug 1, 2005 | 03:57 PM
wrXtian's Avatar
yeah same thing happened to me here.. my cable was unplugged.. so i plugged it back in and reset the ecu.. multiple times.. and i still throw code 17
Old Aug 3, 2005 | 10:55 AM
jmoEF9's Avatar
Have you fed the vss signal to the correct pin in the ECU? If you have vtec, then the ecu should be getting vss signal, BUT just in case!
-jmo
Old Aug 3, 2005 | 04:06 PM
wrXtian's Avatar
Default Re: vss (jmoEF9)
i found my problem.. it was in the guage cluster.. half the wires in that connector were cut off! the other 2 or 3 that were plugged in were taped together w/ masking tape i plugged in the wires the best i could.. hopefully this will fix the problem.. if not i'm gonna go 2 a junkyard and steal a clip off of another civic w/ all the wires
superslowcrx91
May 8, 2013 08:10 PM
hoga113
Mar 8, 2013 04:32 PM
TMC_EF
Jul 16, 2007 10:37 PM
Sleepy_Red_hatch
Mar 17, 2006 06:25 PM
LAWST
Mar 3, 2005 06:51 PM
