H22 Powered EG with superb handling....HOW????????
Old Jul 2, 2005 | 12:01 PM
WH0R3nEF9's Avatar
Default H22 Powered EG with superb handling....HOW????????
Hey all! Ok, so here's my story (I'll try to keep it short)! The other day I went to my brothers friends tuning shop in Chi-town and he gave me a ride in his H22 powered eg with I/H/E and a stripped interior. The car had full 36 way adjustable coilovers (not sure brand) which were tuned in for autocross, 15 inch Heliums with azenis 215s, a 6 pt cage, GSR front sway and 22mm comptech sway/tie combo in the rear, and front strut bar. We were going around 90 degree turns at 70 and 80 mph! It was insane!!
I've always heard that an EG wont handle worth **** with an H22. How did this one handle better than any other Honda I've been in? I know the wheelbase has alot to do with it, but how can I make my GSR handle this well? Thanks for the help in advance!
Old Jul 2, 2005 | 12:17 PM
. a d a m's Avatar
Default Re: H22 Powered EG with superb handling....HOW???????? (1SiKTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKTeG &raquo;</TD></TR><TR><TD CLASS="quote">Hey all! Ok, so here's my story (I'll try to keep it short)! The other day I went to my brothers friends tuning shop in Chi-town and he gave me a ride in his H22 powered eg with I/H/E and a stripped interior. The car had full 36 way adjustable coilovers (not sure brand) which were tuned in for autocross, 15 inch Heliums with azenis 215s, a 6 pt cage, GSR front sway and 22mm comptech sway/tie combo in the rear, and front strut bar. We were going around 90 degree turns at 70 and 80 mph! It was insane!!
I've always heard that an EG wont handle worth **** with an H22. How did this one handle better than any other Honda I've been in? I know the wheelbase has alot to do with it, but how can I make my GSR handle this well? Thanks for the help in advance! </TD></TR></TABLE>
Ok so um, he has 36 way adjustable coilovers, azenis, GSR front/22m Comptech sway/tie bars in the back, and a strut bar, and you're asking why his car handled so well?
H22s are heavy, well, at least compared to a stock D15B or whatever came in his EG. An EG with stock suspension would be affected by this, but your brothers friend's EG had far from stock suspension.
Some coilovers would do your GSR a world of good, a couple strut bars, maybe some Type R sway bars, and a good set of tires would help out your cars handling. Have you ever participated in HPDEs, or ever autocrossed? Theres no point in doing lots of suspension mods when you aren't using your cars stock parts to their full potential.
Old Jul 2, 2005 | 12:44 PM
WH0R3nEF9's Avatar
Default Re: H22 Powered EG with superb handling....HOW???????? (Sh!ttyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">
Some coilovers would do your GSR a world of good, a couple strut bars, maybe some Type R sway bars, and a good set of tires would help out your cars handling. Have you ever participated in HPDEs, or ever autocrossed? Theres no point in doing lots of suspension mods when you aren't using your cars stock parts to their full potential. </TD></TR></TABLE>
I know the suspension helped the handling, I'm not a noob! I'm saying that people have alwasy told me the the extra weight from the B series to the H series would make the car too front heavy and therefore screw with the handling of the car.
As far as my car goes, I already have solid mount front and rear upper bars and a lower tie bar, springs and adj. struts, and decent tires. My car doesn't handle near as well as that eg.
Old Jul 2, 2005 | 12:51 PM
kchungb17a's Avatar
The weight difference isn't really that great. Maybe 150 lbs or so, if that. All you need is to bump the spring rate up in the front. I'm sure his 36 ways are capable of that.
Old Jul 2, 2005 | 01:09 PM
. a d a m's Avatar
As far as my car goes, I already have solid mount front and rear upper bars and a lower tie bar, springs and adj. struts, and decent tires. My car doesn't handle near as well as that eg. </TD></TR></TABLE>
Yeah I figured you weren't a noob, but it really just had to do with the fact that he had a nice suspension setup (and his car was gutted) lol. Your car sounds like it has a decent setup as well. Maybe since you've already got the suspension and tires, you should look into some weight reduction.
Old Jul 2, 2005 | 01:12 PM
. a d a m's Avatar
Default Re: H22 Powered EG with superb handling....HOW???????? (kchungb17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a &raquo;</TD></TR><TR><TD CLASS="quote">The weight difference isn't really that great. Maybe 150 lbs or so, if that. All you need is to bump the spring rate up in the front. I'm sure his 36 ways are capable of that.</TD></TR></TABLE>
True. 150 pounds is a significant difference, but with higher spring rates in the front, the handling wouldn't be that affected by the extra weight at all.
Old Jul 2, 2005 | 01:16 PM
WH0R3nEF9's Avatar
Yeah I figured you weren't a noob, but it really just had to do with the fact that he had a nice suspension setup (and his car was gutted) lol. Your car sounds like it has a decent setup as well. Maybe since you've already got the suspension and tires, you should look into some weight reduction.</TD></TR></TABLE>
Yeah, I'm looking into that. I'm getting rid of the 50lb speaker box, maybe some lighter wheels, and possibly some cf.
Old Jul 2, 2005 | 03:19 PM
Contender25
Guest
Posts: n/a
Do it in this order.
1.Take out the heavy ****, via speaker box, and useless crap.
2.Take out the rear like backseats and ****, that is if you'r willing too and nobody ever sits back they're really.
3.Then get a CF hood, or trunk if you can, either would make a pretty good difference.
Old Jul 2, 2005 | 03:20 PM
Contender25
Guest
Posts: n/a
CF=Less *** Drag.
Old Jul 2, 2005 | 03:53 PM
. a d a m's Avatar
Yeah, I'm looking into that. I'm getting rid of the 50lb speaker box, maybe some lighter wheels, and possibly some cf. </TD></TR></TABLE>
Yeah dude, definitely ditch the speaker box, maybe get rid of the sound deadening tar in the floorboard, and like Contender said, get a CF hood or trunk, or hell, get both.
Old Jul 2, 2005 | 04:16 PM
FULL-REV's Avatar
the h22 is not that much heavier then then the b series. its just a myth
Old Jul 2, 2005 | 04:23 PM
eag36's Avatar
Default Re: (hondaevo)
I also heard somewhere that full roll cages make a world of difference with body roll and handling once you get to the autocrossing level
Old Jul 3, 2005 | 06:05 AM
. a d a m's Avatar
Default Re: (eag36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eag36 &raquo;</TD></TR><TR><TD CLASS="quote">I also heard somewhere that full roll cages make a world of difference with body roll and handling once you get to the autocrossing level</TD></TR></TABLE>
They make the car more rigid. I'm not sure how much of a difference it makes with or without one though. But it definitely does make one.
Old Jul 3, 2005 | 10:02 AM
WH0R3nEF9's Avatar
Default Re: (Contender25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">Do it in this order.
3.Then get a CF hood, or trunk if you can, either would make a pretty good difference.</TD></TR></TABLE>
My goal is to make a street sleeper while retaining most if not all factory options including full interior, pwr steering, A/C and cruise control. I know I said before that I would like some cf, but I want the car to stay stock looking. I removed my factory spoiler and big N1 exhaust. I love the sleeper look and the look on faces when they get raped by a car that looks like nothing!
lakerschamp2000
Feb 5, 2005 02:41 PM
SEQEUL
Jan 10, 2005 10:38 AM
