bigger injecters? what else do i need to change?
Old Jul 2, 2005 | 11:53 AM
-JSpecEk*9-'s Avatar
Default bigger injecters? what else do i need to change?
i am bout to swap my motor in but i still need to add a few things. if i get bigger injecters what else do i need to change so it can run clean??? help me out here i need to swap my **** in.
Old Jul 2, 2005 | 12:02 PM
nota-eg's Avatar
Default Re: bigger injecters? what else do i need to change? (k20a2ek-9)
fuel pump
And a few more details would be nice. What is the current motor? What motor is going in?
Old Jul 2, 2005 | 01:17 PM
Default Re: bigger injecters? what else do i need to change? (nota-eg)
i got a skunk2 manifold, b17 cam shaft but want to get ITR cam shafts, si TB.
Old Jul 2, 2005 | 01:28 PM
sohcvtec1995's Avatar
depending on how big of injectors you go will help determine what all you need. Lets say you do 1 million cc injectors, you will need something to to control the amount of added fuel,I.e. a vafc, a chipped ecu, some sort of Stand alone,etc,etc... Also a fuel pump. like a walboro 190 lph or 255 lph. or once again you can go crazy and do like a 1000 lph external pump. Or even dual pumps.
Old Jul 2, 2005 | 01:39 PM
Default Re: bigger injecters? what else do i need to change? (sohcvtec1995)
right on, so it all depends on what size injeceters i get. anyone have a good brand and size that would help me out so my car can run clean? do you think i can jus get injecters and fuel rail and regulater for now so i can get my motor in and then later on do the rest. i aint goin to race my car right away.
Old Jul 2, 2005 | 01:49 PM
the motor that you are putting in is pretty much stock. just use the factory stuff. A fuel rail is pointless unless you are makeing lots and lots of power, or you need a nitrious tap. A regulator will help, but it can only do as much as your fuel pump will allow. as far as injectors, i would base that off of what you plan on doing with the car in the future.
Old Jul 2, 2005 | 07:38 PM
hondapwr's Avatar
A clean set of stock 240cc injectors should be all you need to make 200HP+
zach1288
Sep 4, 2008 12:03 PM
90civicgsr
Feb 7, 2008 06:17 AM
HondaH22a#1
Jul 3, 2007 10:47 AM
sircrxracer
Nov 21, 2003 10:24 AM
