gsr got slower...anyone know what wrong?
Old Jul 2, 2005 | 11:39 AM
BAYgasDC2's Avatar
Default gsr got slower...anyone know what wrong?
for some reason my car became slower... i used to beat my friends ls by 4-5 cars same bolt ons as me... now my car only beats it by a fender..anyone know whats wrong?spark plugs just changed 1 month ago and oil too..going to change fuel filter soon cause it hasn't been changed in 4 years..could that be the problem? by the way im on uberdata, can that be the problem?
94 gsr
jdm itr headers
short ram intake
blox intake manifold
72 mm rpm service
b&m fuel pressure reg
car sound 2.5 piping
2.5 piping with spoon n1
itr clutch
itr lightened flywheel
p72 obd1 feels chip (uberdata)
Old Jul 2, 2005 | 11:50 AM
bosco500's Avatar
Default Re: gsr got slower...anyone know what wrong? (JDMEKSLEEPER)
Too many variables for someone to "know" what the problem is. Best thing you could do is get the car on a dyno, and make sure it is performing to its full potential. You also need to do a compression and leakdown test. Other than that, your guess is as good as anyone elses.
Old Jul 2, 2005 | 12:04 PM
BAYgasDC2's Avatar
Default Re: gsr got slower...anyone know what wrong? (bosco500)
bump...what numbers should i be exprecting on the dyno?... more feed back
Old Jul 2, 2005 | 01:02 PM
BAYgasDC2's Avatar
bizzummp
Old Jul 2, 2005 | 01:13 PM
projectTeG's Avatar
maybe the guy with the ls got better. but id its tuning and maybe alittle is caused by the tb
Old Jul 2, 2005 | 01:53 PM
tpb18b1's Avatar
just bring it to a honda dealership for a tune up it brobably has never had one. a tune up alone could and probably will increase your engines overall output. i know someone with a 95 mr2 turbo who had his first tune op a 100k and hecould feel a difference. just a thought. good luck.
Old Jul 2, 2005 | 04:36 PM
slipstreamxk1's Avatar
heh it is possible that the ls got better. lots of things could be an issue here. i'd start with a new fuel filter and run some fuel injector cleaner through. you'll be amazed at the difference that injector cleaner can do, i use it once a month to keep things deposit free.
if that dosent help i would go get a compression and leak down test.
if all the above don't work redyno it. certain atmosphereic changes can cause a lack in performance or an untrue tune due to varying conditions.
Old Jul 2, 2005 | 04:40 PM
H.crx-si
Guest
Posts: n/a
Maybe the LS was never power shifting before and now he is? But get that fuel filter changed 4 years is much to long it's likely glogged and affecting performance.
Old Jul 2, 2005 | 05:21 PM
numbnuts22715's Avatar
I think that the driver of the ls may have gotten better, maybe your fuel filter is clogged..
probably something along those lines...
Old Jul 2, 2005 | 05:42 PM
toukna's Avatar
Default Re: (numbnuts22715)
maybe your butt dyno has a malfunction.
Old Jul 3, 2005 | 12:48 AM
BAYgasDC2's Avatar
Default Re: (toukna)
lol well when i used to beat him by 5 cars he had azenis and he always power shifted..i didnt i am going to get it dyno tuned soon...i might use a vafc to make it better..i dont trust uberdata anymore... what do you guys think
vafc
uberdata
Old Jul 3, 2005 | 07:25 AM
uberdata offers more tunability imo but the vafc looks cool heh its up to you on that one.
Old Jul 3, 2005 | 10:00 AM
honda1982's Avatar
Like the other guys say. DO A COMPRESSION TEST!!! and a leak down test. If that comes out fine than the other little stuff is pretty easy. DO A COMPRESSION TEST b4 getting on the dyno. Gsr should read 200psi@sea level on the gauge. Heres a website. Hope your motor is not toast. http://www.c-speedracing.com/h...t.php
Old Jul 3, 2005 | 11:26 AM
TrueUntilDeath.com's Avatar
Default Re: (honda1982)
maybe vtec solinoid?
Old Jul 3, 2005 | 01:48 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (H.crx-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the LS was never power shifting before and now he is? But get that fuel filter changed 4 years is much to long it's likely glogged and affecting performance.</TD></TR></TABLE>
powershifting is not gonna get you 4-5 cars ahead... all its going to get you is gears with no teeth left on them.
Old Jul 3, 2005 | 02:55 PM
H.crx-si
Guest
Posts: n/a
Default Re: (benb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">
powershifting is not gonna get you 4-5 cars ahead... all its going to get you is gears with no teeth left on them. </TD></TR></TABLE>
Powershifting=no loss in speed during shifts so it can get you 4-5 cars ahead depending on the length of the race and also how well the other driver shifts ect. If you think that powershifting doesn't get you better times then regular shifting then hook me up with whatever it is you're smoking. Obviously it isn't good for the tranny bit I don't think anyone said otherwise.
Old Jul 3, 2005 | 04:45 PM
honda1982's Avatar
Unless you are a good Racer and been doing it for awhile than Powershifting is for you. Where every tenth of a sec count. This method is not for Noobie because they could end up killing the Tranny and motor. Overrev is just a sec away. And Who wants to change the Tranny every year. A fully built car doesn't need to Powershift. Powershift VS. Cost. Cost will win everytime.
snk808x
Nov 4, 2009 11:31 AM
blackntegra
Apr 20, 2005 07:08 AM
slowerthanu
Jun 26, 2002 02:53 PM
Leo95SE
Apr 3, 2002 07:37 PM
Unlimited
Nov 28, 2001 03:49 AM
