HELP! Engine decision???? B16a2 with 84mm or 81.5 mm with Ls crank(Built with turbo setup)???
Old Feb 14, 2002 | 07:39 AM
SOUNDEFFECTS's Avatar
Default HELP! Engine decision???? B16a2 with 84mm or 81.5 mm with Ls crank(Built with turbo setup)???
I have a chance to build my 00SI B16 with a good amount of stuff.... Do I go 84mm from GE sleeves or sleeve to 81.5 and then stroke with 1.8 crank?? Or do both 84mm plus 1.8 crank=2.0liter but will I still have a good enough rod to stroke ratio? This will most likely be with mack daddy parts so no half *** cheap parts going in..need advice from experienced builders and drivers,peace!
Old Feb 14, 2002 | 08:11 AM
philo's Avatar
Default Re: HELP! Engine decision???? B16a2 with 84mm or 81.5 mm with Ls crank(Built with turbo setup)??? (S
Generally the the shorter stroke will be more reliable under high boost, but if you dont plan on running 30psi I would bore & stroke it for the extra torque the B16 lacks.
If you plans on a high boost & high RPM setup I would stay with stock bore & stroke and just use boost to make up for the lower displacement.
I went with slightly longer stroke of B17 block and over-bored to 84mm. I think this is a pretty good compromise.
Old Feb 14, 2002 | 02:33 PM
all so we have one for 84mm and 1.7 crank...anyone else have any good experience?? tuend with hondata by the way if anyone cares
Romo Pyro
Aug 1, 2010 01:30 PM
HatchedGTI
Feb 1, 2006 08:28 AM
JSPECHB
Nov 27, 2004 12:01 PM
h22a193
Nov 11, 2003 05:44 PM
FrankEXsteiN
Oct 3, 2002 01:26 AM
