Upgrade Ignition system for C16 (or other high octane fuel)
Old Jul 2, 2005 | 01:47 AM
mrx's Avatar
mrx
Default Upgrade Ignition system for C16 (or other high octane fuel)
Hallo,
yesterday i was told that i maybe have to upgrade my ignition system (B16 OBD0) when running race gas or other high octane fuel, is that correct?
where are the limits of the stock honda ignition system? why do some ppl run MSD's? and if i have to upgrade, what do i have to change exactly?
Thanks
Malte.
Old Jul 3, 2005 | 12:40 AM
mrx's Avatar
mrx
Default Re: Upgrade Ignition system for C16 (mrx)
here are so many ppl with upgraded ign systems around... is there realy nobody who knows?!
why do you all buy MSD's ?!?
Thanks
Malte.
Old Jul 3, 2005 | 12:50 AM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">here are so many ppl with upgraded ign systems around... is there realy nobody who knows?!
Thanks
Malte.</TD></TR></TABLE>
Its afforable and available.
Old Jul 3, 2005 | 06:06 PM
turtle-eg's Avatar
Stock ignition will be fine for race or pump gas.... it's the cylinder pressures that will decided if you need an upgraded ignition.
Old Jul 3, 2005 | 10:31 PM
mrx's Avatar
mrx
Default Re: Upgrade Ignition system for C16 (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">Stock ignition will be fine for race or pump gas.... it's the cylinder pressures that will decided if you need an upgraded ignition.</TD></TR></TABLE>
so if i build a engine with extrem less cyliner pressure then i need a better ignition system - right?
and when is this the case? maybe someone can give an example.
Thanks
Malte.
Old Jul 4, 2005 | 05:03 AM
hondaguyef's Avatar
I like to keep things simple and run the OE ignition. I'm sure I'm not making big power but, it works great for me(w/ race gas and pump gas). I think there have been a few people w/ 500+ whp on an OE igntion and an external coil.
Phil
Old Jul 4, 2005 | 06:24 AM
Turbocivic94's Avatar
I'l be running a msd digital 6 with HVC coil
Old Jul 4, 2005 | 07:19 AM
boosted hybrid's Avatar
Default Re: Upgrade Ignition system for C16 (Turbocivic94)
I have made 600whp several times on 100% stock ignition. You have to make sure that the OEM coil is good before trying it. I see so many customers throw msd stuff on their cars to have it fail, and go back to OEM.
Old Jul 4, 2005 | 09:25 AM
B18CXr's Avatar
Default Re: Upgrade Ignition system for C16 (boosted hybrid)
ditto...
K.I.S.S.
petermartin
Dec 11, 2009 07:59 AM
jmeyer99
Apr 29, 2008 02:29 PM
VTteg
Feb 16, 2006 12:06 PM
UncleRay
Nov 14, 2003 04:38 PM
seppuku
Sep 16, 2003 10:30 AM
