Upgrade Ignition system for C16 (or other high octane fuel)
Hallo,
yesterday i was told that i maybe have to upgrade my ignition system (B16 OBD0) when running race gas or other high octane fuel, is that correct?
where are the limits of the stock honda ignition system? why do some ppl run MSD's? and if i have to upgrade, what do i have to change exactly?
Thanks
Malte.
Thanks
Malte.
Re: Upgrade Ignition system for C16 (mrx)
here are so many ppl with upgraded ign systems around... is there realy nobody who knows?!
why do you all buy MSD's ?!?
Thanks
Malte.
Thanks
Malte.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx »</TD></TR><TR><TD CLASS="quote">here are so many ppl with upgraded ign systems around... is there realy nobody who knows?!
Thanks
Malte.</TD></TR></TABLE>
Its afforable and available.
Thanks
Stock ignition will be fine for race or pump gas.... it's the cylinder pressures that will decided if you need an upgraded ignition.
Re: Upgrade Ignition system for C16 (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg »</TD></TR><TR><TD CLASS="quote">Stock ignition will be fine for race or pump gas.... it's the cylinder pressures that will decided if you need an upgraded ignition.</TD></TR></TABLE>
so if i build a engine with extrem less cyliner pressure then i need a better ignition system - right?
and when is this the case? maybe someone can give an example.
Thanks
Malte.
Thanks
Malte.
I like to keep things simple and run the OE ignition. I'm sure I'm not making big power but, it works great for me(w/ race gas and pump gas). I think there have been a few people w/ 500+ whp on an OE igntion and an external coil.
Phil
Phil
Re: Upgrade Ignition system for C16 (Turbocivic94)
I have made 600whp several times on 100% stock ignition. You have to make sure that the OEM coil is good before trying it. I see so many customers throw msd stuff on their cars to have it fail, and go back to OEM.
Re: Upgrade Ignition system for C16 (boosted hybrid)
ditto...
K.I.S.S.
ditto...
K.I.S.S.
UncleRay
11-14-2003 04:38 PM
