Do i need to convert to mpfi while conv. to obd1????
Old Jul 1, 2005 | 09:16 PM
Fleas_Ef's Avatar
Default Do i need to convert to mpfi while conv. to obd1????
I was reading several post about ppl converting from DPFI to MPFI OBD1, which what is my project now. I dont understand some of the process, any help but mostly DIY websites and **** please, that will help me greatly! I see they just cut all wires going to the resistor box and soder, can i just wire up my injectors? or do i have to wire all that ****?
But basically I am dpfi with B18b sitting in there nice and pretty waiting patiently to raom the streets. I have the ecu jumper harnness thanks to BLOWN90HATCH .... and i have the dizzy jumper harnness thanks to locashracing.com
Thanks peps remember what comes around goes around so help a brother out dont be a dick and say search
Old Jul 1, 2005 | 09:42 PM
vtecn8ive's Avatar
Default Re: Do i need to convert to mpfi while conv. to obd1???? (Fleas_Ef)
https://honda-tech.com/zerothread?id=881705
http://www.geocities.com/c_rexboy/mpfi.html
http://www.geocities.com/kurtsi_on/page8.html
http://www.geocities.com/speed...p.htm
http://www.boosted.org/obd0_to_1.php
http://www.geocities.com/chipm....html
some of these are for d16a6 to d16z6 which is making it obd1 minus the vtec
I would search the faq's if I were you. I know there is **** in there.
Also if you are converting to obd1 I would think you could skip the injector part of it as far as going to the resistor box but I am guessing from the Ecu up to the fuel injectors clips will need to be similar. (if you get what I mean)
-Shane
Old Jul 1, 2005 | 11:09 PM
HiProfile's Avatar
Read that **** and it comes clear. The main problem is that few sites really get into MFPI+OBD1+EngineSwap all in one, or at least the way I'm going.
DPFI cars don't have a resistor box, they just need the 2 injector wires ran out & all four connected to the injector sub-harness.
The other thing to note with the dizzy harness, if its a DPFI car, I'm 99% sure you'll still have to run the crank pos. sensor wires to the right spot. It was made for a mpfi car so you wouldn't have to repin any connector. Check out the http://www.boomslang.us pdf (v1.4) on installing their obd0-obd1 harness, it'll make sense.
Old Jul 2, 2005 | 01:03 AM
Rywire's Avatar
Default Re: Do i need to convert to mpfi while conv. to obd1???? (HiProfile)
http://www.rywire.com for a complete plug and play harness
Old Jul 2, 2005 | 01:05 AM
Rywire's Avatar
Default Re: Do i need to convert to mpfi while conv. to obd1???? (droppedcrxsi)
oh, and fyi locash and jkobd dont mix
Old Jul 2, 2005 | 04:26 AM
vtecn8ive's Avatar
^^ ah man that sucks. They should just make everything compatible ^^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">http://www.rywire.com for a complete plug and play harness</TD></TR></TABLE>
always trying to help out
This guy knows what he is doing.
Old Jul 2, 2005 | 06:27 AM
Rywire's Avatar
Default Re: Do i need to convert to mpfi while conv. to obd1???? (vtecn8ive)
You can repin the locash jumper to work tho, just follow the directions on the jkobd, and you have to swap 2 wires.
Ryan
PS, you can call us, and we can help you with what to swap.
Old Jul 2, 2005 | 04:13 PM
Fleas_Ef's Avatar
Damn so why dont they work together!! just another damn issuse swaps are quite difficult sometimes but just thinkin about the end result
sakasaku
Jan 10, 2010 06:46 AM
keenspeed94
Apr 20, 2007 11:06 PM
SupraRXZ
Feb 5, 2006 06:57 PM
jdmtim
Oct 5, 2004 07:46 AM
AmauryR
Feb 10, 2003 06:38 PM
