Car running good or not 1320 times and compression checks provided
I clocked 15.1@90.13 in my 95 Si hatch with full interior
I was hitting 2.3 60ft ets and my 1/8ths where 9.8.
My mods are I/E clutch flywheel chipped computer.
The car seems slow, Compression readings are 195,195,200,195,
1 check engine which is 02 shouldnt affect anything
No your times are pretty good you should be able to get it into the high 14s but ive seen alot worse with others b16s, Are you running an O2 sensor at all becasue that does give your comp alot of info?
I was getting 9.70 to the 1/8th in a 2000 Civic SI I/H/E. You can do better. Just takes practice. Get you 60ft down to atleast a 2.2 - 2.0. I see 14s in your car!
thanks guys....yeah i used to have a 91 h/b with a JDM B16 I/H/E clutch flywheel chipped computer. I could never get it below 15.0@96 my traps where allot faster but the time stayed the same. My fast 1/8 was like 9.8 thats with the same tire setup i am using now. 15" SSR type X with 195/50/15 dunlop Fm901's
Try using a 205 tire instead of a 195. Use 25psi tire pressure. Then launch the **** out of it! Dont be scared to launch it out of the hole! I launch at 6000rpm on the track. Maybe a little bit more. Try not to get too much wheel spin when doing it.
TylerC161
Apr 17, 2008 04:30 PM
CivicT
Jun 14, 2001 12:29 AM
