Pilot bearing help.. On 88Hf
Old Jul 1, 2005 | 08:30 PM
ivanson's Avatar
Default Pilot bearing help.. On 88Hf
Im trying to remove the pilot bearing out of my flywheel
but the flywheel is still on the engine. I couldnt take out
the flywheel. I borrowed a tool from autozone but it didnt work.
Do you have to pull it out or pushed out (toward the engine).
Plz anyone help me. Thanks
Old Jul 2, 2005 | 04:54 AM
Sikocivic's Avatar
Default Re: Pilot bearing help.. On 88Hf (ivanson)
Just take the flywheel off. You should always get the flywheel turned whenever you replace the clutch anyway. Alot of auto supply shops can do that for you,NAPA,Bumper to Bumper or AutoZone should be able to turn it for you. I think I paid $25 to get mine done.
Old Jul 2, 2005 | 09:06 AM
ivanson's Avatar
Default Re: Pilot bearing help.. On 88Hf (Sikocivic)
What do you mean by the flywheel getting turned?
Old Jul 2, 2005 | 11:00 AM
EFbomb's Avatar
the pilot bearing had to come out the back of the flywheel
"turning" or "resurfacing" the flywheel is kinda like getting your brake rotors resurfaced when you change brakes. It will take off the top layer of metal on the friction surface so when you install the new clutch/brakes it has a fresh surface to mate with, not one that hte last clutch was tearing up/glazing ect... This will also help breakin.
replace your rear main seal while your flywheel is off, or you will get super pissed when it starts leaking after you put the tranny back on and drive it.
Old Jul 2, 2005 | 05:52 PM
ivanson's Avatar
Default Re: (EFbomb)
the thing is that i cant take the flywheel off.
The bolts are really tight in there.. I got a hold
of an impact gun and i still cant take them off...
Old Jul 2, 2005 | 05:55 PM
theinfamouskonrad's Avatar
Default Re: (ivanson)
well in order to take out the pilot bearing you must take off the flywheel. Even if you did somehow break it out, the new one must go in from the back of the flywheel.
Old Jul 2, 2005 | 06:24 PM
90civicturboed's Avatar
u need a nice strong impact gun and the sucker will come right off then u can tap the piolt bearing out with a hammer
Nathan007
Transmission & Drivetrain
Jun 19, 2009 06:31 PM
vtechatch
Sep 25, 2007 09:17 PM
skunkwhat
May 15, 2005 09:04 PM
Vtec-Jesus
Aug 27, 2003 01:42 PM
3rdGteg
Jul 18, 2002 11:48 PM
