Question on carbon build-up on pistons
Old Jul 1, 2005 | 07:54 PM
Nsane1's Avatar
From: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Default Question on carbon build-up on pistons
ok, doing a head gasket change and noticed quite a bit of carbon build-up on my pistons. I scrubbed them down but, I was wondering if anybody had a good way to clean the carbon off the pistons and get the carbon out of the cylinder. I'm kinda stuck and the carbon seems pretty abrasive. I don't wanna scar my cylinder walls. And I won't be taking the pistons out of the engine so plz don't mention (had a horrible time w/ the crank bolt and still can't get it off). Help me plz.
Old Jul 1, 2005 | 08:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Question on carbon build-up on pistons (Nsane1)
you don't need to remove the crank pulley if you're just removing the head anyways.
Best thing to do is after the engine is up and running...remove the plugs, drop in about an ounce or 2 of sea foam, let it sit for a couple hours, then fire it up. After doing so, my compression is now 240 across all 4, and burns no oil- used to burn quit a bit, and with the detergents, it cleans soft carbon and hard carbon build up
lude98SH
Jul 31, 2007 12:50 PM
turbotime
Jun 21, 2006 06:56 PM
b16 matt
Sep 26, 2004 05:15 PM
dubnine
Mar 26, 2004 10:22 AM
KooK
Jan 8, 2003 06:18 PM
