GSR block with b16 head
Old Jul 1, 2005 | 06:27 PM
Sketch_hs's Avatar
Default GSR block with b16 head
What compression ratio with this yield?
Same Headgasket?
What timing belt?
Thanks!
Old Jul 1, 2005 | 06:33 PM
Kyles ej1's Avatar
Default Re: GSR block with b16 head (Sketch_hs)
dont do it unless u plan on boosting or something cuz it will lower your cr
Old Jul 1, 2005 | 10:26 PM
underb00steg6's Avatar
Default Re: GSR block with b16 head (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">dont do it unless u plan on boosting or something cuz it will lower your cr</TD></TR></TABLE>
why should he boost ??.... b16 head on a gsr block will raise the compression....good for all motor with a type r tranny .....put type r pistons ... you have pretty much a poorman's type r.
Old Jul 2, 2005 | 12:00 AM
Kyles ej1's Avatar
Default Re: GSR block with b16 head (underb00steg6)
no it will lower compression
Old Jul 2, 2005 | 04:07 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">What compression ratio with this yield?
Same Headgasket?
What timing belt?
Thanks!</TD></TR></TABLE>
You can get a general idea of compression ratios with different head and block combos with this calculator: http://www.c-speedracing.com/h...c.php. Won't be exact, but you get a good idea of what direction you're heading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 &raquo;</TD></TR><TR><TD CLASS="quote">
why should he boost ??.... b16 head on a gsr block will raise the compression....good for all motor with a type r tranny .....put type r pistons ... you have pretty much a poorman's type r.</TD></TR></TABLE>
The B16 head will decrease compression with a B18C1 block.
Old Jul 2, 2005 | 08:34 AM
Calliefornia's Avatar
Default Re: GSR block with b16 head (rodrez.)
I had the exact setup in my CX last summer, Stock B18C1 block with a B16A3 head(all RRR head internals) and a RRR LSD trans.
**I used the Type R Head Gasket and the Type R Timing Belt and it will decrease the Compression Ratio**
http://www.cardomain.com/ride/324623/2
Modified by Calliefornia at 9:48 AM 7/2/2005
Modified by Calliefornia at 9:53 AM 7/2/2005
Old Jul 2, 2005 | 08:54 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
there really is no reason for doing this.....
Old Jul 2, 2005 | 09:01 AM
94civicCx's Avatar
Default Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">there really is no reason for doing this.....</TD></TR></TABLE> No u can do this just do an search on poorman and u'll find all ur answer. also with just the stock block and b16 head ur compression will drop but with jdm p30 or ITR piston it an whole different story
Old Jul 2, 2005 | 09:29 AM
Default Re: (94civicCx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicCx &raquo;</TD></TR><TR><TD CLASS="quote"> No u can do this just do an search on poorman and u'll find all ur answer. also with just the stock block and b16 head ur compression will drop but with jdm p30 or ITR piston it an whole different story </TD></TR></TABLE>i understand the idea of a poormans itr, but unless you change the pistons and cams and lma's and do the blending in the valve bowls...you still have a gsr with a b16 head. if the b16 head was such a great head for the 1.8 honda would have slapped it on the gsr in 94 and called it done instead of spending countless hours and dollars developing the gs-r head and 2 stage intake
now i can see putting this head on if the original poster messed up the p72 head and has found a b16 head cheap. but to take off a perfectly good head just so you can have a "poormans itr" is kinda dumb
if he really wants to see some gains he should throw a set of jdm r cams in that thing, and slap on an AEBS intake manifold. i did this to my stock gsr and could not believe the top end pull that intake made and i still have the stock tb and exhaust cam. i wish i could have used this intake manifold on my last gsr i had i think the power gain would have been quite a bit more with the added compression from p73's
https://honda-tech.com/zerothread?id=1080997
Old Jul 2, 2005 | 10:08 AM
Tuesdaynightfever's Avatar
I had the b16a head/tranny on my gsr...Ran very nice. I would def. recommend it for an all motor.
Old Jul 2, 2005 | 03:08 PM
Sketch_hs's Avatar
I'm turbo charged with a b16 right now. i'm looking to go to a b18c block for more displacement and power, and hopefully lower the compression ratio.
what about the b16 block related parts like the oil pump and water pump? different for b18c?
So i need the b18c or type-r timing belt and HG?
Old Jul 2, 2005 | 04:25 PM
Default Re: (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">I'm turbo charged with a b16 right now. i'm looking to go to a b18c block for more displacement and power, and hopefully lower the compression ratio.
</TD></TR></TABLE>water pump and oil pump are basically the same, if you want more pressure switch to a crv oil pum, same p/n as itr
also you should use the b16 gasket and t-belt
Old Jul 4, 2005 | 08:54 AM
Sketch_hs's Avatar
b16 t-belt??
I was thinking i needed a b18c or ITR belt because of the taller deck hight?
Old Jul 4, 2005 | 10:01 AM
BBPEG6's Avatar
you do, type r or gsr belt is needed for that block.
Old Jul 4, 2005 | 10:19 AM
Dueceification's Avatar
My friend has a b18c1 block with a b16a head. We used a GSR water pump and a GSR timing belt. We also installed some ITR Pistons & Rods also installed some CTR cams and Valve train. His Poorman's ITR beats up on real Type R motors. I think it's because it has slightly higher compression due to the Cosmetic Head gasket and it's running a custom obd1 p28. Plus all the bolt ons.
If i was you I'd use the GSR Water Pump and GSR Timing Belt. If not i suppose you could use a ITR water pump and ITR timing belt. The ITR water pump pumps more then the GSR one. Also with a Cosmetic head gasket you could yeild the same if not higher comp ratio as the GSR. (i think) Are you going to run stock cams? Pistons? Do you have the GSR head?
Old Jul 4, 2005 | 11:31 AM
Sketch_hs's Avatar
i'm going to slap my b16a head on the GSR block. Thanks for your help
this should give about 10:1 CR and a lot more power than my 1.6
who has a gsr short block?
Will everything else from my swap work?
ie alternator, engine mounts, intermediate shaft....?
Old Jul 5, 2005 | 02:50 PM
neophyte210's Avatar
whats funny is that i have the exact opposite setup as you now ... i have a b16a2 bottom end and a p-72 gsr head ..... everyone tells me that this combo makes more compression
Old Jul 5, 2005 | 05:00 PM
Sketch_hs's Avatar
ie alternator, engine mounts, intermediate shaft....?</TD></TR></TABLE>
Old Jul 5, 2005 | 05:16 PM
eg6ajk's Avatar
calculator
http://bojangs.com/calculator/
Old Jul 5, 2005 | 06:46 PM
jmcmil6's Avatar
Default Re: (neophyte210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neophyte210 &raquo;</TD></TR><TR><TD CLASS="quote">whats funny is that i have the exact opposite setup as you now ... i have a b16a2 bottom end and a p-72 gsr head ..... everyone tells me that this combo makes more compression</TD></TR></TABLE>
my all motor car is set up the same way, and it does yield more compression due to the shape of the gsr's chambers, i have oversized ctr's in my b16block and the head has skunk2 stage II's...i wanted to switch to an ls block, but they said w/ all the same parts, ie pistons, etc..using that gsr, the compression would be way too much...
fyi to those that dont know, increasing the bore, completing your chamber will also lead to more compression
Old Jul 5, 2005 | 08:20 PM
Daniel san's Avatar
that's cool
how's that working for you ?
you have any numbers ?
Old Jul 5, 2005 | 09:05 PM
SCIVIC94's Avatar
Default Re: (eg6ajk)
bump for caculator
Old Jul 5, 2005 | 10:14 PM
Sketch_hs's Avatar
Old Jul 5, 2005 | 10:17 PM
Sketch_hs's Avatar
oh and what about my tapped b16 oil pan? will that work on a GSR motor?
are all the oil pans the same?
Old Jul 6, 2005 | 04:15 AM
peshte's Avatar
wouldnt it be wiser to do a B16 head w/ a B20z block?...im not sure if i would lower the compression?
