boggin in all gears
Old Jul 1, 2005 | 02:10 PM
Thanks knightsport!'s Avatar
I'm a Jackass
Default boggin in all gears
my car recently started to bog in it all at low rpms. i talked to one of my friends and he said i might need a new tranny. but i changed my spark plugs a few months ago and when ever i started my car when it was cold the rpms would bounce. does anyone know if this could be related? and how i can fix it
Old Jul 1, 2005 | 04:25 PM
SHhh__VTEC's Avatar
i'm in the same boat. I used my VAFC2 and lean out the low rpm in the narrow range and it helped a little. My car gets kinda bad when it warms up and starts squeeking. The squeeking comes from the intake manifold but I CAN NOT figure where in the IM it's coming from. I'm really having trouble solving this problem. Can anybody help me on this??
Old Jul 1, 2005 | 05:01 PM
slomofo's Avatar
GDD Member
You won't believe me when I say this, but it kinda sounds like a problem with MAP sensor vaccuum. Maybe the TB mounted MAP is loose, or the firewall mounted MAP has a leak in the hose. Or I could be wrong all together.
Old Jul 1, 2005 | 06:16 PM
Fobstylez's Avatar
Default Re: (slomofo)
not sure if its the same as my issue but I find that around 2k rpm its boggy. Like its kinda pulling me back in a way. Is this typical of h22a4? Never had a lude before so I dont know. Car drives fine but unless I keep it above 2k its slow as hell
Old Jul 1, 2005 | 07:31 PM
BlueLude94's Avatar
Have you changed the fuel filter recently, never underestimate the "quick fix."
Old Jul 1, 2005 | 08:46 PM
Tacoma Luda's Avatar
Default Re: boggin in all gears (dirrtybird)
aight its your Oxygen Sensor. If your at cold rpm's and its like a 2.1k and it bogs down to like 1.5 somewere in that area . Yeah its your sensor . when you know its totally gone is when it does that sh*t all the time like my friends car.
Old Jul 1, 2005 | 08:50 PM
Fobstylez's Avatar
Default Re: boggin in all gears (Tacoma Luda)
is there anyway to check out your OS to see if it went bad? I dont think its the fuel filter, car runs fines unless its at low rpm. I havent noticed if this is when its cold or not but I think its like that all the time.
hondanc7
Honda S2000
Mar 19, 2009 02:10 PM
Agent Zero
Honda S2000
Feb 6, 2008 05:07 PM
xASAPx
Sep 15, 2006 09:21 PM
92jdmhatch
Honda S2000
Aug 17, 2005 11:14 AM
preylude99
Honda S2000
Jul 21, 2003 06:58 AM
