rings for srp pistons
i was just wonderin if i can run stock rings with srp pistons on a d16z6. the pistons are 10.5:1 comp stock bore. I am gonna be runnin nitrous with the head milled .030" so compression should be around 11.3:1 just want to know if that is a good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n20sol »</TD></TR><TR><TD CLASS="quote">i was just wonderin if i can run stock rings with srp pistons on a d16z6. the pistons are 10.5:1 comp stock bore. </TD></TR></TABLE>
I dont think so, the ones I got had narrower ring grooves.
oxSLEEPERxo
Jun 24, 2007 12:11 PM
