What can cause my ground Vtec Solenoid to melt
Old Jul 1, 2005 | 12:34 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default What can cause my ground Vtec Solenoid to melt
thanks, for some reason, my vtec solenoid wire melts
any reason as to why?
Old Jul 1, 2005 | 12:47 PM
MugenHonda's Avatar
Default Re: What can cause my ground Vtec Solenoid to melt (MugenHonda)
ttt
Old Jul 1, 2005 | 01:44 PM
Relic1's Avatar
melting wire means too much power being pulled through it.
either the wire is too small (swapped and added in) or your VTEC solinoid is bad.
Old Jul 1, 2005 | 01:53 PM
Deemeetree's Avatar
Electrician
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">melting wire means too much power being pulled through it.
either the wire is too small (swapped and added in) or your VTEC solinoid is bad.</TD></TR></TABLE>
I highly doubt the wire melted due to too much voltage running through it. Stranded copper could easily flow 600v through it, it's the insulation that breaks down at certain voltage and temperature.
Is the wire completely melted, or is the insulation melting off?
Old Jul 1, 2005 | 02:51 PM
MugenHonda's Avatar
Default Re: (Deemeetree)
insulation melting off.
The way it melts is this.
When i try to start the car, the starter turns, but the thing is, it turns and usually stops, sometimes it will turn all the way and start the car, therefore, no melting, but most of the time, it turns, and feels like not enough juice, although the battery and alternator are good.
When it doesn't have enough juice, the vtec solenoid ground melts, and i see smoke.
I traced the ground to where it is wired to in the harness, and see no melting at where it is wired too, so i assume since i grounded the harness, must be too much power there.
I'll add a thicker wire to see what happens
Old Jul 1, 2005 | 02:52 PM
MugenHonda's Avatar
Default Re: (MugenHonda)
yeah i used speaker wire lol
Old Jul 1, 2005 | 03:28 PM
h22 booster's Avatar
if you have a short somewhere...which you might, it'll melt where ever is least resistance. Sounds like way too much current is going through the wire then is supposed to. The signal to the vtec solenoid shouldn't melt speaker wire.
Old Jul 1, 2005 | 03:30 PM
MugenHonda's Avatar
Default Re: (h22 booster)
it's a ground, how could there be too much current
Old Jul 1, 2005 | 04:46 PM
96CivicBoostCoupe's Avatar
its either shitty wire or a direct short
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">it's a ground, how could there be too much current</TD></TR></TABLE>
current runs through the ground side, the ground completes the circuit
Old Jul 2, 2005 | 11:15 AM
MugenHonda's Avatar
Default Re: (96CivicBoostCoupe)
I grounded a harness in the fuse box that shouldn't have been grounded
thanks
CrooksEK
Jul 23, 2014 11:45 AM
civic_boy23
Feb 2, 2007 07:15 PM
ball
Oct 28, 2002 08:55 PM
schwett
Jun 2, 2002 12:34 AM
