Will a Si throttle body bolt on to a HF head?
I'm pretty sure this been answer before but
I need some quick help. Will this help the engine
performance. Also i just broke my tps...And i'm
thinking of getting the Si t-body instead of just the tps
Any suggestions will be helpful. THanks
Yes it will bolt on, but you're not going to see much (if any) of a gain. The HF motor is an 8 valve, and honestly, if you're looking for more power, swap out the motor. You'll get frustrated with trying to squeeze anything more out of that HF motor.
I dont know honestly if it will fit. I know that the Civic CX TB's have such a small butterfly that a bigger oem tb won't open to wot if at all, dont remember exactly.
yea...i know the hf r weak.
but its for the tps. or will the car still run without it?
also let me add i smoked a 200sx on my 60hp engine.
ahahahaha
ahahahaha
Swap out for the good TPS then... and remember to adjust it to 0.45V closed. You just need to either file or dremel a notch in the "screws" the factory uses to attach the TPS to the TB, stick with the stock TB, it'll work a lot better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivanson »</TD></TR><TR><TD CLASS="quote">yea...i know the hf r weak.
ahahahaha</TD></TR></TABLE>
EK FLY
Oct 8, 2005 07:36 AM
audioroach
Feb 23, 2003 08:54 PM
