speakers dont work
I have a 93 civic ex. I know nothing about audio but recently all my speakers randomly died all at once. My sterio will turn on but the amp under my seat and my speakers wont work. This leads me to believe maybe a fuse blew. Which fuses should I check/ what else could it be? Anyone have a diagram of the fuse box under drivers side dash? Thanks for your time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">This should be in the audio forum.</TD></TR></TABLE>
Can you hear them screaming LOCK
check the fuse if you are using a monster cable kit next to the battery (cylinder fuse). Then check the fuse in the amp (2 prong fuse). Then i would check the fuses inside (under steering column) and check for audio. There are also fuses near the battery in the engine compartment. I know I've had to replace that one before
Just check the cylinder fuse that connects to the battery,amp fuse and check to see if you can find another place to ground the ground wire,oh and make sure your speaker wires -black +positive are not touching because it usually makes my 2 10'' jl audios go blank leaving me with the factory speakers only.Good luck
dima
Audio / Security / Video
28
Jan 5, 2005 11:30 PM
