rims offset for 15 X 7
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
I think 38mm is a better choice.
stock enkeis are +50mm offset. The +38mm offset are spaced more outward. Not a bulldog set up though. I once tried a 205/55/15 with 15x7 team dynamics with a 36 or 38mm offset and it did rub when cornering. this is on stock springs and shocks.
Dont buy a 205/55/15. Unless you live in the woods.
Rodney's right. 38 is a very bad choice unless you're strictly running 205s. Then the 38s make the car turn in crisper. 43/45 is the only to fit 225s without rubbing, although the 16" +50 Mugen wheels fit, but it could be because they're 16". +43s might rub the trailing arm and the fender lip a little bit, but at least it's centered. With 38s you *might* be able to baseball bat the fender lips enough to fit, but as soon as you correct camber you're screwed.
Austin
Jan 28, 2003 03:24 PM
