problem with B16a swap into 98 civic
Ok, I have the swap done for the most part but when i fire the engine up a couple codes came up. I am using a OBD-II GSR ECU and the only code left I have yet to figure out is the code regarding the CKF (Crank Function Sensor). Now in my searches I have found that the B16a has no CKF sensor and that the Integra ECU requires one. Does anyone have any ideas, last resort would be to just swap the ECU for maybe a 99 si. Thanks for any help.
No, even the 99-00 b16 have the ckf. You have two options. Add the ckf which requires an obd2 oil pump. Or get a conversion harness and run a obd1 ecu which you should do anyways.
