slotted/drilled rotors?
Old Jul 1, 2005 | 08:21 AM
ieatrice's Avatar
Default slotted/drilled rotors?
is there a correct or incorrect way to install the rotors?
which one goes on which side? does it matter? just curious.
Old Jul 1, 2005 | 08:29 AM
integraver's Avatar
Default Re: slotted/drilled rotors? (ieatrice)
slots go ALONG the braking and NOT against the braking
Old Jul 1, 2005 | 08:33 AM
rufridn's Avatar
the one on the left goes on ur driver side, the right goes on the pass side
Old Jul 1, 2005 | 08:35 AM
DnB TeK's Avatar
there usually markings stamp on the rotor stating either L for left and R for right....and if there is not then my guess in the pic, is the left is for left side....i have power slot on my car and the marking where stamp on the rotor....so yes it does matter which direction they go....good luck
Old Jul 1, 2005 | 09:12 AM
PostMASTER-S27's Avatar
F*ckin DOPE!!!
Old Jul 1, 2005 | 09:14 AM
enrique's Avatar
suposidly you can do it either way. the intended way is for the slots/fins to fan out. I heard in japan that some people do it the opposite way. the logic behind this is that it cuts air into the rotor rather than out of the rotor.
edit: why is this in the apperance forum?
Old Jul 1, 2005 | 11:12 AM
ieatrice's Avatar
thank for the replies guys!! time to put these babies onnn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enrique &raquo;</TD></TR><TR><TD CLASS="quote">edit: why is this in the apperance forum?</TD></TR></TABLE>
i don't know. lol
Old Jul 2, 2005 | 07:08 PM
ieatrice's Avatar
hmm.. so are the following cars with slotted/drilled rotors on backwards??
Old Jul 2, 2005 | 07:16 PM
.1type.'s Avatar
... not hard to install, one say L for left side, and the other R for right side... not rocket science
Modified by 1type at 8:40 PM 7/2/2005
Old Jul 2, 2005 | 07:36 PM
papito_85's Avatar
we learn something new everyday.
Old Jul 2, 2005 | 07:47 PM
92SleeperH23's Avatar
those are some shiny ******* volks
Old Jul 2, 2005 | 10:01 PM
!LL W!LL's Avatar
no soy maricon!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. so are the following cars with slotted/drilled rotors on backwards??
yup installed wrong
Old Jul 2, 2005 | 10:07 PM
FlatBrokeHatch's Avatar
Default Re: slotted/drilled rotors? (1type)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1type &raquo;</TD></TR><TR><TD CLASS="quote"> ... not hard to install, one say L for left side, and the other R for right side... not rocket science
No doubt...they should say it on them.
Old Jul 3, 2005 | 12:03 PM
rodrez.'s Avatar
Default Re: slotted/drilled rotors? (!LL W!LL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by !LL W!LL &raquo;</TD></TR><TR><TD CLASS="quote">
yup installed wrong</TD></TR></TABLE>
Why would they work any different if they were flipped around the other way?
Old Jul 3, 2005 | 12:16 PM
JDMHN8's Avatar
Default Re: slotted/drilled rotors? (rodrez.)
Unless there are directional vanes inside the rotor (which yours don't have), then it makes absolutely no difference what side the slots go on...
Old Jul 3, 2005 | 09:42 PM
ieatrice's Avatar
Default Re: slotted/drilled rotors? (JDMDA9)
oh ok, thanks again!
Old Jul 4, 2005 | 02:49 AM
I B Z's Avatar
Default Re: slotted/drilled rotors? (enrique)
it all depends on the fins..... if there directional then u have to put them on that way. if there just straight up then it doesn't matter.
Old Jul 10, 2005 | 11:25 PM
ieatrice's Avatar
bump for a final answer.. so all the pics i posted are installed wrong, correct?
btw, there are no stamps that say which side they should go on because these are actually brembo blanks that were professionally drilled and slotted.
Old Jul 10, 2005 | 11:31 PM
enrique's Avatar
you can install them either way. one way fans air out the other forces air in. different methods of cooling. kind of like fans for your car, one can push air the other can pull air.
carracr625
Sep 23, 2009 10:06 PM
95JDM
Jun 27, 2007 05:06 AM
2.7liter
Suspension & Brakes
Mar 5, 2007 02:27 AM
carboy247
Jul 13, 2005 02:14 PM
fcuked
Feb 9, 2002 03:24 AM
