Passing a NC Inspection!!!!!????
Old Jul 1, 2005 | 04:01 AM
speeddemon1's Avatar
Default Passing a NC Inspection!!!!!????
Does anyone know how to pass a NC inspection having a JDM swap and ECU?? For some reason the emissions check will not recongnize the ecu or anything to do with the car!!!! Any ideas?
Drive It like you stole it. I tried to get an inspection and couldn't read car it does have an obd 2ecu but its jdm what do I do
Modified by speeddemon1 at 5:38 PM 7/1/2005
Old Jul 1, 2005 | 04:59 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Passing a NC Inspection!!!!!???? (speeddemon1)
You *must* have an OBDII computer to pass in NC if your county requires emissions testing and your car is a '96 or newer.
Your options are as follows:
1) Get an OBDII computer
2) Register your car in a non-emissions county
Old Jul 1, 2005 | 09:40 AM
Haleiwa-Brando's Avatar
Default Re: Passing a NC Inspection!!!!!???? (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
2) Register your car in a non-emissions county</TD></TR></TABLE>
There are non-emissions counties in North Carolina? This leads to my next question: If there are non emissions counties in North Carolina, does the person geting said vehicle registered need to prove his residency in said 'non-emissions' county?
Old Jul 1, 2005 | 10:47 AM
Splat's Avatar
Default Re: Passing a NC Inspection!!!!!???? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
There are non-emissions counties in North Carolina? This leads to my next question: If there are non emissions counties in North Carolina, does the person geting said vehicle registered need to prove his residency in said 'non-emissions' county?</TD></TR></TABLE>
http://www.ncdot.org/dmv/vehic....html
Not nearly as many as there used to be, but yes, there are a few. Not sure what you have to do as far as residency goes. When I was faced with a potentially unpassable truck, I was going to "sell" it to my father-in-law so it would be registered in Beaufort County (no emissions).
Then they (allegedly) changed the laws, which will exempt all pre-'96 cars from emissions testing statewide.
Old Jul 1, 2005 | 01:20 PM
SearchBeforeUPost!'s Avatar
only 96+ are required to pass the emissions inspection.
If you register in an non-emissions county, you must prove residency there.
Old Jul 1, 2005 | 04:42 PM
whats up man it is an obd2 computer but thecar runs great they just can't identify the ecu any other suggestions
Old Jul 1, 2005 | 05:38 PM
Stunna BEN's Avatar
Don't call it a comeback
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">There are non-emissions counties in North Carolina? This leads to my next question: If there are non emissions counties in North Carolina, does the person geting said vehicle registered need to prove his residency in said 'non-emissions' county?</TD></TR></TABLE>
Move 20 min away to south carolina, and have NO emitions
And to answer your question, no.
Old Jul 1, 2005 | 06:18 PM
Default Re: Passing a NC Inspection!!!!!???? (SearchBeforeUPost!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! &raquo;</TD></TR><TR><TD CLASS="quote">only 96+ are required to pass the emissions inspection.
If you register in an non-emissions county, you must prove residency there. </TD></TR></TABLE>
Maybe I wasn't clear enough in my questions What I mean is, will simply being a resident of the State of North Carolina work, or does your actual mailing address have to be with in the non-emissions county?
Old Jul 1, 2005 | 06:28 PM
REDLINEtypeR's Avatar
NC sux. Move to CA!!!
Old Jul 1, 2005 | 07:03 PM
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">What I mean is, will simply being a resident of the State of North Carolina work, or does your actual mailing address have to be with in the non-emissions county?</TD></TR></TABLE>
You need to have "a" mailing address in the non-emissions county, since your vehicle will have to be registered there. Not quite sure what that takes. I don't know if a PO Box counts for that.
In NC, the magic triangle involves your vehicle registration, your insurance, and your driver's license. **** up on any one of the three, and it can get expensive.
Old Jul 2, 2005 | 04:37 AM
Default Re: Passing a NC Inspection!!!!!???? (REDLINEtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDLINEtypeR &raquo;</TD></TR><TR><TD CLASS="quote">NC sux. Move to CA!!!</TD></TR></TABLE>
You suck. I-40 west. Use it! Get out of wilmington.
angel949
33
Sep 2, 2008 08:28 PM
NathanMorris
Oct 4, 2006 03:36 AM
Aloha04MSM
Jan 24, 2006 03:27 PM
SRd240sx
Aug 30, 2005 11:46 PM
wid326
26
Aug 19, 2004 07:21 PM
